Old 11-15-2012, 05:11 PM   #1
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
Function of "blow off" pipe run?
Hi all - in my trailer, the previous owner updated plumbing to pex/pvc but didn't run it all within the pan. I may be redoing some of it and I wondered if you can tell me what the function/need is for a pipe run that seems to just spurt water out under the trailer? Is this a standard pipe run on airstreams that the previous owner replicated?
In the attached photo you can see the incoming city water line and a couple valves. The first valve seems to turn on/off the city water. Just after that, there is another valve that I believe just outlets under the trailer.
What on earth would that be needed for? The only thing I can imagine is to release pressure in the plumbing system. Is it really necessary?
Or maybe it is to bleed air out of the system?
Thanks in advance.
CA_Tallguy is offline   Reply With Quote
Old 11-15-2012, 05:24 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
It looks like a low point drain used for getting all the water out in the fall for winterizing and draining the antifreeze in the spring.
Lumatic is online now   Reply With Quote
Old 11-15-2012, 06:13 PM   #3
CA_Tallguy's Avatar
Zavalla , Texas
Interesting. That may be what he was trying to do but I don't think it is low enough. Wouldn't it need to be below the fresh water tank? Being above the floor, it is also above that tank. I guess it could drain stuff above the floor in the plumbing though.
Old 11-15-2012, 06:18 PM   #4
Southwestern , Ohio
Not sure how yours is plumbed, but in every Airstream that I have seen, the freshwater tank is above the floor. (Also, it has its own separate drain.)
Those are definitely low point drains.
Nuvite-F is offline   Reply With Quote
Old 11-15-2012, 06:18 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
There are usually 2 low point drains. One in the front for the water tank, and one in the rear.
Old 11-15-2012, 06:20 PM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
Since the 60s freshwater tanks have been below the floor in the bellypan, although I don't know about newer models.
Old 11-15-2012, 08:59 PM   #7
Southwestern , Ohio
Oh?
In our 1980 Caravelle the freshwater and blackwater tanks are above the floor. The greywater tank is below the floor so that the shower can drain into it.
Our 1960 Pacer was the same, except it didn't have a greywater tank.
Old 11-15-2012, 09:58 PM   #8
rogerdodger's Avatar
Fresno/Clovis , California
Oh?
So is my Argosy. However, since the freshwater tank has it's own drain valve, I would think one low level drain is enough for winterizing. But probably not a problem in Hollywood, LA area.!! Freezing?
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 11-15-2012, 10:29 PM   #9
CA_Tallguy's Avatar
Zavalla , Texas
It has barely been getting into the 70's lately (I'm down camping in san diego) so YES! LOL My heater has been running at night. It's awful.
Old 11-15-2012, 10:37 PM   #10
CA_Tallguy's Avatar
Zavalla , Texas
Yeah, I'm pretty sure mine is in the belly pan. I've only owned it a few weeks so far and this is my first airstream. But I've explored the ol' girl pretty well, at least in the main cabin area. I suppose that I might have overlooked it. I would love to inspect it along with the other stuff that I am assuming I can't get to very well in the belly pan.
Old 11-16-2012, 05:33 AM   #11
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Does the line coming from under the cover lead to the pump?
Not all early trailers had a fresh water tank drain.
In my '81 the only way to "drain" the freshwater tank was to pump it out with the water pump. There was a valve that opened to allow the flow of water to exit the trailer that did funciton in the manner you describe...it simply was an open pipe under the trailer.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
