Old 04-19-2015, 08:18 PM   #1
Airborne6's Avatar
2015 23' International
Lakeview , Arkansas
Fullway termination valve
Not sure what the fullway termination valve is or where it's at.
Also we just took ownership of this new 23D and we received a curtesy pack containing a water pressure regulator among other things. I mentioned to the salesman that I thought the Airstreams came with an integrated water pressure regulator. He said no. I've watched many YouTube clips in prep of taking ownership of this Airstream and I swear the clips mentioned that Airstream was one on the only ones that have the integrated pressure regulator. Am I wwwwrong?
Some days your the bug.
Some days your the windshield.
WBCCI # 1959
Black 2015 Toyota Tundra TRD Pro CrewMax
2015 23D International Signature (Salsa)
Stella our Bull Pointer mix
Airborne6 is offline   Reply With Quote
Old 04-19-2015, 08:22 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
That is my understanding also. There have been reports here of the built in regulator failing and causing fill or leak issues.
MICHAEL
Old 04-19-2015, 08:58 PM   #3
ckottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The water inlet in your photo is for Black Tank Flush, the city water inlet is the other one. Never mix them up.
Your city water inlet has the water pressure regulator built in right there within the assembly, has the pressure it limits embossed on it, and works fine.
cheryl
ckottum is offline   Reply With Quote
Old 11-12-2016, 08:54 PM   #4
2016 16' Sport
Albuquerque , New Mexico
I too wonder where/what the fullway termination valve is. The warning tag on mine is on the City Water Inlet. It flushes the black tank too, so I'd better know the whereabouts of this valve.
Spizzlepop is offline   Reply With Quote
Old 11-12-2016, 09:19 PM   #5
1979 23' Safari
Wayland , New York
Fullway termination valve is what almost any RVer knows as your dump valve.
That picture is your black water flush connection, not your fresh water inlet for drinking water.
Old 08-29-2018, 10:17 AM   #6
2019 22' Sport
Santa Fe , New Mexico
Is this a term used for the handle on the black water tank?
Cherokee88 is offline   Reply With Quote
Old 05-14-2019, 02:29 PM   #7
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Originally Posted by HiJoeSilver View Post
Fullway termination valve is what almost any RVer knows as your dump valve. That picture is your black water flush connection, not your fresh water inlet for drinking water.
I believe you are wrong. Airstream's placard is incredibly bad English. NO Airstreamer I know calls the dump valve(s) a flush valve. They are dump valves.
Also, the "fullway termination valve" is missing in action. What is it, where is it?
As you can tell, I am a little hot about this stupidity on the part of Airstream.
Zep
Old 05-14-2019, 04:16 PM   #8
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
The decal is to remind u to open the black water dump valve while using the pictured inlet with a hose (with water running) to flush the black water tank.
Old 05-14-2019, 04:42 PM   #9
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
The SOB MoHo that is parked next to me in the storage lot has the identical sticker warning about the "fullway" valve, so it's not just an Airstream Stupidity.
SSquared is offline   Reply With Quote
Old 05-14-2019, 05:41 PM   #10
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I think it's the back flow preventer that fails. Different animal.
2019 Ford Expedition Platinum
Old 05-14-2019, 05:46 PM   #11
Wayne&Sam's Avatar
Images: 21
It's probably a standard sticker. Just think it though. You want the black tank dump valve (or whatever you want to call it) open so you don't flood the interior of your camper.
You know, when you hook up the flush hose and then your neighbor asks you a question and you go to his trailer and then they serve drinks and three hours later you remember you hooked up the flush hose.
Old 05-14-2019, 07:28 PM   #12
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
The term "fullway", in this use, is an adjective or definition of the dump valve; meaning the valve in its full open position is open to approximately the same diameter of the connected pipe. The full way is open. It is not a proper name of a specific valve.
A sewer dump valve (blade type) is a fullway valve. A ball valve is a fullway valve. A gate valve can be a fullway valve, but not always.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Mid-bath termination valve fix Zeppelinium Waste Systems, Tanks & Totes 14 01-25-2013 01:49 PM
Instructions on how to replace rubbers on termination valve thetford Holland General Repair Forum 1 03-30-2009 03:47 PM
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 07:08 AM
Termination caps jcanavera Waste Systems, Tanks & Totes 7 02-08-2004 08:17 PM
