Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 08-31-2008, 10:03 PM   #1
mustang's Avatar
1999 27' Safari
Kent , Ohio
Freshwater tank on a 1971 sovereign
Has anyone change the fresh water tank on there 31 foot sovereign. I would like to know is it easier to get to it from underneith (drop belly pan) or over top? (remove floor) and pictures if they are out there. Thanks
mustang is offline   Reply With Quote
Old 09-01-2008, 05:36 AM   #2
Retired.
. , At Large
I replaced the fresh water tank in our Sovereign a couple of months ago. It was not hard, but the tank is big and bulky. It will only come out from the bottom, you need to unhook the sensor wires, and water fill, drain, and vent hoses. Then unbolt the angle iron from the front of the water tank support area, and slide the plywood base out from under the tank. I had a friend help by holding the tank up while I slid the plywood. After it comes out, just stick the new tank in place, and slide the plywood back in place.
Old 09-01-2008, 09:00 AM   #3
mustang's Avatar
1999 27' Safari
Kent , Ohio
It seems that I cannot get to my wires and filler hose. Did you do that after it was out ? Or do I disconnect the filler hose were it is accessable and when reinsatlling snake the hose back in?
Old 09-01-2008, 09:33 AM   #4
Yep.
But you can disconnect the wires, if you can locate a person with a triple jointed elbow, or is it a double jointed screwdriver?
Darn, I don't remember what I forgot!
Everything must be disconnected, "before" you drop the tank.
Andy Rogozinski
Inland RV Center
Corona, CA
I don't want to melt freshwater tank bertro Repairing/Replacing Floor &/or Frame 3 04-11-2008 06:34 PM
freshwater tank leaking rec Waste Systems, Tanks & Totes 4 01-07-2008 12:30 PM
How can you tell if your freshwater tank is truly clean? JimGolden Fresh Water Systems 24 10-30-2007 08:44 AM
Is something wrong with my freshwater tank? TitusLivy Fresh Water Systems 11 04-28-2007 09:15 AM
Leaky Freshwater Tank rochar3 Fresh Water Systems 6 02-15-2007 05:05 PM
