Old 02-17-2009, 08:57 PM   #1
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Fairmont , West Virginia
Question Fresh Water Tank outlet leaking
On my fresh water tank under my front couch the out let for the pump on the tank side is leaking! it apears that the treads are damaged and very thin any ideas???
shermantic is offline   Reply With Quote
Old 02-17-2009, 08:58 PM   #2
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
how do I figure out how large my holding tank (S) are and if I have just a black tank or if I have grey tank too
Old 02-17-2009, 09:52 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You should not have a grey tank in a 72. If you did you would have a drain valve for each tank. With no grey tank water that is poured down the sink will immediately exit by way of the sewer line connection.
I am going to guess that your black tank is around 12 to 15 gallons is size. An easy and effective way to find out the exact size is to pour water down the toilet and see how many gallons it takes to fill the tank.
Richard
Old 02-18-2009, 04:53 AM   #4
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Shermantic,
Would teflon pipe dope or teflon tape work to make the connection more secure. I do not know if you can re-tap threads in a plastic fixture.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 02-18-2009, 07:00 AM   #5
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
If me dump valve is closed what happens to the grey water?
Old 02-18-2009, 07:37 AM   #6
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by DEITZ645 View Post
Shermantic,
You could re tap but you would have to go one size larger. say a 1/4 to 5/16 or 3/8.
Michelle TAC MT-0
Sarah, Snowball
Old 02-18-2009, 11:00 AM   #7
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
On my 67 Tradewind The freshwater tank outlet was a male nipple,1/2 or 3/4 inch. I used a straight plastic threaded coupler and screwed it on to the tank nipple using a plastic two part epoxy as glue/sealer. This gave me a brand new thread to work with. The coupler was larger in diameter than the bottem of the tank. This made the coupler support the tank on that end. I used a piece of 3/8" plywood the size of the tank to shim it up in the air to remove the strain from the nipple. Adios, John
Diesel1 is offline   Reply With Quote
Old 02-18-2009, 02:21 PM   #8
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Problem solved I retaped it and used a brass 1/2 3/8 bushing and alswell
Old 02-18-2009, 04:01 PM   #9
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
not a pretty picture
your question....
"If me dump valve is closed what happens to the grey water?"
Like in mine, i'm sure, you will now have a rising mess in the shower/tub....unless the dump cap is open.
Old 02-18-2009, 04:37 PM   #10
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
It will go out the dump connection, or at it least at if did on my 68. Makes sure the tank is empty, open the valve and look inside and see it a pipe come into the side on the downstream side of the valve gate. My unit was designed that when the valve was closed waste to black tank grey out the dump valve. If you cap the dump valve and left the black tank valve open the grey water then went into the black tank. Simple and very efficient.
I used a cap with a hose connection, I would connect the hose to run the grey out, If I couldn't dump grey I capped the outlet and let the grey go to the black tank. Didn't hold much but it would keep you from fouling the area you are camping in.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 02-18-2009, 06:04 PM   #11
1972 25' Tradewind
Madison , Wisconsin
Greywater
Originally Posted by Melody Ranch View Post
your question....
My 72 will flow the grey water out of the dump. The valve only controls blackwater. If I dump greywater I have the blue boy hooked up--or it's on the ground.
Smokin Camel is offline   Reply With Quote
Old 02-18-2009, 08:31 PM   #12
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
thanks Smokin Camel! Your right
Old 02-18-2009, 08:43 PM   #13
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
your lucky
In my 66 the water does not have access to the black storage. If the cap is on it flows to the path of least resistance....ie., the shower pan floor outlet. I learned the hard way.
Black Water Tank Shut-off Leaking tntom Waste Systems, Tanks & Totes 2 07-03-2008 06:38 PM
Leaking fresh water tank turbo8 Fresh Water Systems 5 08-19-2007 12:44 AM
Leaking Fresh Water Tank gaylejoe Fresh Water Systems 9 09-30-2006 07:04 PM
Anyone fixed a leaking fresh water tank? JohnGalt48 Fresh Water Systems 2 06-28-2004 01:59 PM
HELP fresh water tank leaking wvabeer Fresh Water Systems 2 04-08-2003 11:10 AM
