Join Airstream Forums Today
Old 12-31-2011, 07:15 AM   #1
lboyd
2003 25' Safari
Fallbrook , California
Fresh water tank drain valve replacement
I just purchased a 2003 25' Safari. I know there has been alot of discussion regarding this but how do you replace the fresh water tank drain valve (the cheap plastic one)? I've removed the two screws from the flange but it seems that there must be a clamp on the barbed fitting inside the tank housing. That brings up another question. Is the tank housed in a protective outer shell? Do you access the tank itself from inside the trailer? Do I have to drop the tank from below the trailer?
lboyd is offline   Reply With Quote
Old 12-31-2011, 07:26 AM   #2
RLS
RLS's Avatar
2004 25' Classic
Longwood , Florida
If it is like ours, there should be a cover plate right next to the valve on the underside. Just take the screws off and you can get to the short hose.
Julia & Bob
W/ Neka & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 04-18-2012, 08:08 AM   #3
susans69's Avatar
1976 Argosy 26
Lake Wales , Florida
My cheap plastic drain plug is broken. Did you replace yours and with what?
susans69 is offline   Reply With Quote
Water tank drain valve replacement lboyd Fresh Water Systems 5 12-31-2011 02:51 PM
Fresh Water Tank Drain Valve greatlakes Fresh Water Systems 28 08-09-2011 11:54 AM
Fresh Water Drain Valve Wrench withidl Fresh Water Systems 6 05-13-2011 07:31 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
