Old 06-02-2015, 11:46 AM   #1
1973 25' Tradewind
Beautiful , Oregon
Fresh water system Gurus Please help a fellow out
Hi folks,
Would some of you plumbing gurus enlighten me on the niceties’ of the fresh water system?
I am re plumbing my 73 Tradewind with Pex,using the crimps system and so far so good. If not slow due to head scratching. I am putting shut off valves to each component for ease of servicing, as well as, trying to locate things were they are easiest to get to.
I have couple of questions I was hoping you could answer for me to keep me on the path to success.
Where are check values necessary? On the “In” side of water heater and the outside” of water heater? Other? I have a shut off valve at the street water inlet, do I put a check valve in front of it before it feeds the system?
Should some kind of pressure relief values be part of the system?
How is the air bleed off the fresh water tank as it fills up?
Please add any "be sure" to do things if you would.
Well, any help would be appreciated I do not want a soggy trailer or one that does not supply water properly.
Many Thanks you in advance
Tony
Tony S is offline   Reply With Quote
Old 06-02-2015, 11:58 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Generally the freshwater pump has a check valve built in. You'll want a check valve just inboard of the city water inlet as well.
I don't think you need checkvalves around the water heater, but if you want to winterize using the fill-with-antifreeze method you might want bypass valves so you can shunt water around the water heater and just drain the heater in the winter, to save you 6 gallons of antifreeze.
My trailer has a pressure regulator just inboard of the city water inlet, and the water heater has a pressure relief valve built in.
My freshwater tank has a small vent tube above the filler tube, and air vents back to the filler neck. My Argosy has an above-the-floor fresh tank, where I think yours is below the floor but the theory is probably similar.
— David
Old 06-02-2015, 01:38 PM   #3
1973 25' Tradewind
Beautiful , Oregon
I suspect you are have the conical adjustable regulator in the picture. I was going to leave it out and go with one pre white house when infilling from city.
I will put a check valve as you suggest at the infill.
I am lucky that I have a built in by pass on water heater. So that is covered. I had a mobil tec here to look at doing my propane and he suggested the check valve at the water heater but I had never heard of that.
Anyone else with any suggestion or pictures please put forward.
Tony
Old 06-02-2015, 02:16 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Simplify things and just get a current city connection for the side of the trailer. That connection will have the check and regulator built in.
There is no need for "local valves" at each faucet. Whenever you need to work on the plumbing just turn the pump off or disconnect from the city. Same effect
2004 Excursion 4x4
Old 06-02-2015, 04:53 PM   #5
1973 25' Tradewind
Beautiful , Oregon
I get it. Simple is good. What I did was took Colin C advice he gave on vap show 189 and went with the local valves for the ability to service or shut down while continue a trip. I suspect it is over kill. So was epoxying the floor and a few other things I guess why stop now.
The reason I didn't go with the current style city connection is I could not find it in metal. I didn't want "chrome" plated plastic. I rigged this up. Kind of different. I hope it works out.
Tony
ID:	239855   Click image for larger version
Old 06-04-2015, 11:38 AM   #6
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
I used pex tubing and shark bite fittings
silver 67 is offline   Reply With Quote
Old 06-04-2015, 03:49 PM   #7
Zil
egg harbor city , South Jersey
Cold water into heating tank will expand. Usually the water backs into a line. Check valves on hot water will cause relief valve leak.
Zil is offline   Reply With Quote
Old 06-04-2015, 04:48 PM   #8
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
The hot water expands into the hot water tank. There is an air bubble on the top of the tank for this.
Let's not forget drain valves.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 06-04-2015, 08:29 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Modern systems use a check valve and a three way valve to bypass the water heater.
The check valve is positioned on the hot water outlet in such a manner as to let the hot water flow out when in "use" mode. It prevents RV Antifreeze from going back thru the hot water outlet.
I think low point drains are a waste of time and money. Plus they can be a headache if one leaks. How does one determine the low point? What if you can't park on a level surface when winterizing.
Eliminate the low point drains and use an air compressor when winterizing.
Also pressure regulators should not be hard piped into the coach. When they fail, and they will. It is a big job to remove and replace.
Locate fittings in a convenient place for future access, especially valves. Even if it takes a little more piping to make this happen.
TG Twinkie is online now   Reply With Quote
Old 06-04-2015, 09:01 PM   #10
1973 25' Tradewind
Beautiful , Oregon
Thanks for the input.
Here is what I have been working on. Looks simple when done definitely some head scratching. There is all the function and then there is the placement and competition for thight space. I still have the vent duct coming in the closet over to the right against wall. I still have one crimp I can't get to. There has to be a smaller tool out there or some tricky way. It is just after the valve for draining the cold water. The closet width is not wide enough for the tool I have. i have some of the front done also. Have not hooked up the the water heater yet. I will put the check valve in as you suggest for water going out. How about a check valve in front of the water tank.
I have one just after the water coming in. I used white pipe for water coming in and drains. Also for the short run to the toilet. The plan is to frame for a Polycarb floor above the plumbing the is hinged so I can see things and get to them when I have to. I have some scrap Polycarb sheets.
I did already plumb the low point drains but do hear your point. The way I also heard it and the reason I did plumb for low point drains front and aback was have as set in back and front open when running down the road
and let it splash forward and back and drain.
My hot water heater came with a by pass valve, I believe, so that is covered
Tony
ID:	240024   Click image for larger version
ID:	240026   Click image for larger version
Looking for Electrical System Gurus KCN Generators & Solar Power 2 11-17-2014 11:33 AM
FYI Notes Laying Out Fresh Water System Tony S Fresh Water Systems 0 09-04-2013 11:07 AM
ATTN: Land Yacht Gurus -> Your opinion please: 1994 Legacy. 34' Diesel Pusher colinear Land Yacht/Legacy Motorhomes 4 03-01-2010 11:31 AM
Changing out Sony System - help please GT1963 Audio, Video & TV 0 01-18-2009 11:46 AM
