Old 01-18-2016, 03:54 PM   #1
1972 Argosy 22
Shalimar , Florida
Fresh water pipe diameter
Going with PEX IN A 72 Argosy 22, confused about the copper to PEX connections. Bought a 3/4 and 1/2 adapter, fits the PEX fine but will not mate to the copper coming from the fresh water tank or the hot water heater inlet. What am I doing wrong? Thanks Jim
Andersojd is offline   Reply With Quote
Old 01-20-2016, 07:58 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Are you connecting at the water heater?
My unit is a 1986 and it used polybutylene tubing instead of the copper. My guess is that you would need either to come off the WH with a male pipe thread adapter or a ferrel fitting adapter.
In my opinion starting at the WH is by far the most rugged and most reliable.
If you are just getting started I would purchase a PEX crimp style tool, not very much money $30 and use crimp rings. Should be less expensive in the long run and you won't need to worry about the connections.
If you are worried about getting the PEX into hard to reach places you can tie a cord onto the old pipe and just pull the pipe out, then you can pull the PEX in. I did not find any of the tubing installed with hidden clamps tight to the trailer, it all came out with little trouble.
Just going to PEX will increase your system performance and be nearly bullet proof for freezing.
sgschwend is offline   Reply With Quote
Old 01-20-2016, 11:00 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You are dealing with copper tubing not copper pipe. Tubing is sized by outside dimensions. Pipe is inside dimensions.
Not sure why you are leaving some copper in the coach other than the hot and cold lines going to the shower faucets. Everything else should be relatively easy to replace with PEX.
Old 01-21-2016, 07:48 AM   #4
Mission , Texas
For copper tubing sizes see this
https://en.m.wikipedia.org/wiki/Copper_tubing
The likely reason why the PEX fittings won't work on your copper is because the copper expanded from frozen water inside of it.
When I went to check the water system on our new to us 75 Overlander (with air first) it leaked. Checked PO receipts, many for water leak repair. Started checking repairs and remaining copper, a disaster! Much of the copper that wasn't split, had expanded to a new dimension you can't purchase.
So the copilot and I talked, we went to the store, $500 and a couple of days later ALL of the fresh water plumbing was on PEX with new faucets and valves.
nrgtrakr is offline   Reply With Quote
Old 01-22-2016, 11:44 AM   #5
1977 31' Sovereign
Lynnwood , Washington
Those threads are probably 5/8 "tubing" - different stuff than "pipe."
Get a brass fitting adapter = 5/8" tubing to 1/2" pipe. Ace is the place.
Tom
TomKirk is offline   Reply With Quote
Old 01-22-2016, 04:06 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
It is not unusual for older Airstreams to have copper tubing that has been subject to freezing temperatures while containing water. This causes the diameter of the pipe to expand slightly, and it will no longer fit into standard fittings.
The best fix is to replace all of it. Failing that, it may be possible to solder a short piece of new copper pipe inside the old expanded copper pipe, to get a piece of standard size.
Old 01-22-2016, 05:32 PM   #7
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
copper tubing size
Early Airstreams typically have copper tubing not plumbing pipe and is sized differently. This type of pipe is typically used in air conditioning systems. I went to a refrigeration supply house to get a proper size splice to fix a broken line when I got my '77 and it was only a couple of dollars. I believe they also had pieces to solder in to convert to plumbing pipe sizes.
rvb is offline   Reply With Quote
Old 01-22-2016, 07:10 PM   #8
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Just a corollary to the above;
Many of you use those "Y" valves to connect two or more hoses to the city water bib, and/or use those related little shut Off Valves. (SOVs)
Going with an RVTravel.com suggestion, I installed a little SOV at the water inlet to the trailer, so that I could shut off the water when we went out for the day; To preclude possible problems from leakage. However......
The water flow was rather slow to the AS, and troubleshooting, I found that those valves, and the 'Y's have a 5/16" passageway, where-as, my hose was 5/8" dia. See the problem?
I went to the hardware store, and purchased a 1/2" SOV, drilled out some threads to accept some purchased male/female hose ends and squeezed them together with some epoxy. Now, It works fine.
MelGoddard is offline   Reply With Quote
Fresh water hose diameter BSalinger Winterizing, Storage, Carports & Covers 19 04-13-2013 01:29 PM
Need Drain Hose Diameter for Penguin ASAP BrockLives Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-04-2011 05:59 PM
7" diameter tail light back plates Rosemary Lights - Interior & Exterior 10 04-15-2011 05:56 PM
Zip Dee Roller and Slat Diameter? Silverfly Awnings 5 04-24-2007 05:53 AM
Adding an electric jack to 2005 Bambi -- what diameter? platbr Jacks, Stabilizers, Lifting and Leveling 1 09-27-2005 03:40 PM
