Old 12-28-2012, 09:02 AM   #1
2011 28' Flying Cloud
chanhassen , Minnesota
Fresh Water Low Point Drain on 2010 FC 28'
Dear Fellow A/S Enthusiasts:
On a recent trip, on our way to a spot w/no fresh water, I filled up the fresh water tank. When we arrived, I saw water gushing from the broken white plastic shutoff valve - quick thinking led me to removing the bubble gum from my mouth and plugging the leak and then finishing the repair with black gorilla tape.
Funny - before leaving I thought while looking at the plastic shutoff valve that I didn't like the design and how hard it is to reach the handle - maybe a premonition?
I found one on Ebay that is made of Aluminum and has a tap drain vs. the cheap "switch" design.
From other threads on this subject, it seems the engineers at Airstream didn't design an access panel or long enough hose to remove & replace the drain tap.
Anyone with experience in this department, please let me know your thoughts.
Thanks much,
Ken Tuvman
kentuvman is offline   Reply With Quote
Old 12-28-2012, 09:16 AM   #2
dznf0g's Avatar
Oswego , Illinois
Not sure on your 28'er, Ken, but on mine, I can get to the short hose connecting the valve to the tank through an opening in the floor under the removeable closet floor. It won't be easy...have to be a bit of a contortionist to get to the hose clamps, but it can be done.
-Rich-
Old 12-28-2012, 06:21 PM   #3
Will see if that works - why do these guys use such a cheap valve & then make it next to impossible to R&R?
Thank You,
Ken Tuvman
Old 12-28-2012, 07:05 PM   #4
dznf0g's Avatar
Oswego , Illinois
Hmmmm, I have no come back for that question!
-Rich-
Old 12-29-2012, 01:23 PM   #5
Thanks, Rich
I'm interested in purchasing the aluminum unit I saw on Ebay so I won't have to deal with replacing again!!!
He sells model to accomodate a 3/8" or 1/2" hose - do you happen to know hose diameter? My unit is a 2010 FC 28'
Thank You,
Ken Tuvman
Old 12-29-2012, 02:37 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
An aluminum water valve under the trailer may corrode and stick badly. I wonder if there are any made of brass.
doug k
Old 12-29-2012, 03:04 PM   #7
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Do your valve's look like these?.....
The brass petcock's I keep lubed with silicone grease, and the white FW drain with silicone spray. The rear low water drain valve looks like the water heater by-pass valve's and is in the curbside rear storage compartment.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-29-2012, 03:07 PM   #8
dznf0g's Avatar
Oswego , Illinois
Originally Posted by kentuvman View Post
Thanks, Rich
I'm not 100% sure, but I think 1/2".
-Rich-
Old 12-29-2012, 08:37 PM   #9
The one on EBay looks unbreakable - buy this and another seller has the drain valve
http://www.ebay.com/itm/170856910315...S:1123&vxp=mtr
http://www.ebay.com/itm/261118858013...013%26_rdc%3D1
Looks like a much better set up than the plastic units
Thank You,
Ken Tuvman
