Old 02-23-2016, 12:39 PM   #1
2010 28' International
2009 17' Sport
Boerne , Texas
Fresh Water Leak
2010 International Serenity 28'. I first noticed that the fresh water holding tank was running out daily, were as it used to take 3-4 days to use up the water in the holding tank, Under trailer inspection revealed fresh water is leaking from black plastic pan under trailer, located between wheels perpendicular to trailer body, held on to bottom with galvanized metal straps. Is this the actual holding tank, or is there another holding tank under this black plastic pan?
(As a side note would also like to add that we also had an invasion of mice, I have trapped 5-10 mice, leak happened during mice invasion time period)
Before I try to remove this pan and look for source of leak, any suggestions, information, tips, hints, warnings, etc, would be greatly appreciated.
Jhemix
jhemix is offline   Reply With Quote
Old 02-23-2016, 01:21 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I am assuming that the pump was not on for that period of time and the leak is in fact from the tank.
You have to drop the pan for any inspection. Mice will eat at some plastics when new because of the gas given off.
2004 Excursion 4x4
Old 02-23-2016, 01:43 PM   #3
2009 17' Sport
Boerne , Texas
Thanks for quick reply Howie,
The pump does not come on or cycle while water is leaking out, Before I drop pan, are there any water lines that need to be dis-connected? I have attached picture of small hole in black plastic pan, where water is leaking. Is this pan the actual tank? or is the tank inside the pan?
JH
Old 02-23-2016, 01:46 PM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Looks like it might be the actual tank.
BambiTex is offline   Reply With Quote
Old 02-23-2016, 01:51 PM   #5
HowieE's Avatar
Images: 12
Can't tell from the picture but I suspect that is the tank. Take a stiff wire and push it up through the hole. If there is a tank inside, and that is just a cover pan, you should touch it within 2 inches.
The only piping to the fresh water tank are the fill tube and the pickup tube.
2004 Excursion 4x4
Old 02-23-2016, 01:56 PM   #6
2009 17' Sport
Boerne , Texas
The hole looks like it was possibly patched at one time. There is a smaller tank under front galley seats, I am guessing that this is a pressure tank, because even though the pump is on, it never comes on or cycles off and on while water is leaking out of bottom pan. If this bottom pan is the actual fresh water holding tank, patching small hole is easy fix. However if bottom pan is not the actual tank, I don't want to just patch hole and forget about it...... if the leak is internal, it could cause rotting/rusting , etc, problems.
Old 02-23-2016, 02:11 PM   #7
2009 17' Sport
Boerne , Texas
I pushed up wire as you suggested Howie, wire went through a bit of foam, (from feel of it), then stopped within 1/2". So I guess next step is let water all drain out then try to back off bolts and ease pan down to attempt access to leak....Thank you for your suggestions, and I will re-post as this progresses...
JH
Old 02-24-2016, 11:01 AM   #8
2009 17' Sport
Boerne , Texas
Found post that is exactly the same as the leak on my 2010 International Serenity 28',
Very well documented by user:
http://www.airforums.com/forums/f443...ng-114716.html
Old 02-25-2016, 06:08 PM   #9
2009 17' Sport
Boerne , Texas
Removed tank today, cracked connection on tank at pump line output.
Old 04-11-2016, 01:15 AM   #10
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
That same type connection is what blew out on my city water fill line just as it goes into the pressure reducing valve. Spent about $7 on parts from Home Depot and 2 days changing out the line.
Mike1997 is offline   Reply With Quote
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 03:45 AM
How long fresh water stays fresh? cellarrat Boondocking 28 02-07-2016 01:39 PM
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
Fresh water leak - help wayner1239 Fresh Water Systems 6 10-01-2003 02:20 PM
