Old 06-02-2016, 01:11 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Fresh water drain
FW tank was 25%, opened plastic drain behind tires. Took 24 hours to drain; I could only get a really slow trickle. Any ideas why draining so slow?
DeltaRon is offline   Reply With Quote
Old 06-02-2016, 01:15 PM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Are you sure you had the drain all the way open?
I've drained ours a few times now, and while it was slow, it wasn't that slow.
SeaLevel is online now   Reply With Quote
Old 06-02-2016, 01:19 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
First guess would be some debris across the opening in the tank. You should be able to remove the drain cock and check it out. I would not just blow what ever is there back into the tank as it will reappear in time.
2004 Excursion 4x4
Old 06-02-2016, 01:54 PM   #4
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I agree with the idea of debris/sludge/slime in the tank and it's blocking the drain.
I've seen the drain valves attached in one of two ways and there may be other methods too.
1) Valve is threaded and can simply be tightened and loosened (installed and removed) by rotating the body clockwise and counter-clockwise.
2) Valve is attached to some sort of plastic hose using a hose clamp. If you're drain is like ours it has two screws attaching it to the sheet metal pan surrounding the tank. After removing those screws the drain valve can be pulled out to access the hose clamp.
After removing the valve you can perform a series of fill and flush and may want to add some bleach to help remove the residue that may have accumulated in the tank.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 06-02-2016, 02:02 PM   #5
Long Island , New York
Could you give us an idea of how old your AS is, and your previous use of the fresh water tank drain? With a new-ish trailer [2015], it is unlikely IMO that you have any build-up of organic sludge, unless something like leaves etc. got in when you filled the tank previously.
Some debris from construction might be blocking your drain, just inside the tank? Is this the first time you have had this problem, or perhaps the first time you have used the tank and drain?
Earlier threads discuss the drain, for instance:
http://www.airforums.com/forums/f443...in-151072.html
and ROBERT CROSS has shown a replacement option in metal in Post #5 therein.
Removal of the plastic drain may be a little dicey IMO, as access to the hose clamp is tight apparently, and there is very little play in the length of the tubing to the actual tank.
I would consider holding a compressed air nozzle over the discharge, held loosely by hand, and blowing air back up the drain, to see if the rate of discharge temporarily increases. You might be able to push possible debris away from the back of the drain.
Good luck.
Peter
PS -- Ditto to earlier comment about drain possibly not being open all the way. Ours needs to be turned 180 and point to the rear of the trailer, to be fully open.
PS2 -- The following sub-forum's list of topics includes other previous threads on point:
http://www.airforums.com/forums/f443/
Old 06-02-2016, 02:22 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
Run a pipe cleaner up it
CRH is offline   Reply With Quote
Old 06-02-2016, 03:02 PM   #7
HowieE's Avatar
Images: 12
That is not a good idea as the drain is a right angle and even if you could you are only pushing the problem back into the tank to reoccur later.
2004 Excursion 4x4
Old 06-02-2016, 03:29 PM   #8
CRH
1995 25' Excella
xxxxx , xxxxxx
I dunno. It worked for me...I think "the problem" broke up and flowed out.
Old 06-09-2016, 04:24 PM   #9
Wondering if you got this straightened out?
Peter
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
fresh water drain: broke it off. help jparks Fresh Water Systems 12 10-07-2009 06:20 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
Fresh water drain ? TexasStars Fresh Water Systems 6 10-29-2003 12:09 PM
Fresh water drain Happycampers Fresh Water Systems 0 07-21-2003 04:54 PM
