Join Airstream Forums Today
Old 09-10-2011, 04:03 PM   #1
Nice guy
1995 28' Excella
Asheville , North Carolina
Freeing up water drain valve
I have a 1995 Excella that has a white/plastic or nylon water drain valve in bottom of the tank behind the curb side wheels. I am unable to twist it open and do not want to apply to much pressure and break it. Is there some product or way that I can use to loosen in up so it will twist open?
ashe is offline   Reply With Quote
Old 09-10-2011, 05:51 PM   #2
DanielB's Avatar
1974 31' Excella 500
Huger , South Carolina
Pliers should do it.
Underway's the only way.
DanielB is offline   Reply With Quote
Old 09-10-2011, 06:16 PM   #3
dznf0g's Avatar
Oswego , Illinois
Silicone spray. Let it soak into the o-ring.
Old 09-10-2011, 07:46 PM   #4
Silver Otter's Avatar
1999 30' Excella 1000
Nellysford , Virginia
Send a message via AIM to Silver Otter
Yep, I'll be replacing mine tomorrow because I twisted too hard without soaking it in lube. It worked once, but seized up the second time I tried to open it.
Greg and Linda Heuer
'99 Excella 30 w/HAHA - The Silver Otter
'08 Chevy 2500HD 6.6 DuraMax w/MBRP dual pipes
TAC VA-18 | WBCCI 1927 - Unit 149 | AIR 53869
http://www.linkedin.com/in/gheuer
Silver Otter is offline   Reply With Quote
Old 09-10-2011, 08:04 PM   #5
2000 25' Safari
Davidson County , North Carolina
Someone posted a few months ago that they made a tool to turn this valve out of a piece of aluminum chanel. I can not find that post, but would like to make myself one of them.
Alan
Air #15745
Old 09-10-2011, 08:10 PM   #6
richinny's Avatar
2011 34' Classic
Westchester Cty. NY , & Miami FL
http://www.airforums.com/forums/f443...nch-77246.html
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 09-10-2011, 08:16 PM   #7
airdreamers's Avatar
1985 25' Sovereign
Milford, CT & Nokomis, FL , Connecticut & Florida
Opps!!
Breaks pretty easy doesn't it!
Need a new one Oh Boy!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 09-10-2011, 09:13 PM   #8
jump's Avatar
1982 31' Excella
lubbock , Texas
If pliers don't work ...
Try a hammer ... that'll open her up .... real good.
Then you can go buy a new one to install ...
and won't THAT be fun
jump is offline   Reply With Quote
Old 09-10-2011, 09:43 PM   #9
tkowalyk's Avatar
2006 25' Safari
North Wales , Pennsylvania
Images: 11
Silicone spray is the way to go. Worked like a champ for me. Liberally spray on the spray and let it penetrate (15 minutes is probably good, I waited over night) and reapplied after the valve was open.
In fact I used a bit of silicone spray on several moving parts all over the rig and everything is moving / working a bit easier.
Tom & Lori
2006 Safari 25SS
2007 Dodge Durango -- 5.7 Hemi
tkowalyk is offline   Reply With Quote
Fresh Water Tank Drain Valve greatlakes Fresh Water Systems 28 08-09-2011 11:54 AM
Revisit water heater relief valve leaking Silver Otter Water Heaters, Filters & Pumps 18 05-23-2011 08:52 AM
Fresh Water Drain Valve Wrench withidl Fresh Water Systems 6 05-13-2011 07:31 PM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
Hot Water from Cold Valve txhippiefish Fresh Water Systems 26 04-03-2011 11:05 AM
