Old 01-15-2013, 03:26 PM   #1
2012 30' Classic
Bigfork , Montana
Fork down toilet bowl
Not realizing the dirty opaque dish water contained a fork, we emptied a pan of it into the toilet of our Classic 30' Airstream. Should we even attempt to retrieve it and if so does anyone have a suggestion for doing so. Any chance it might come out the other end?
Thank you! Bert
Bert Gildart is offline   Reply With Quote
Old 01-15-2013, 03:32 PM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
I'm not an expert when it comes to the china toilet, but I think the principle is still there (it's a straight shot down to the black tank).
If the fork is made of steel, you might go to a hardware store and look for a telescoping device that has a magnet on the end.
Good luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 01-15-2013, 03:43 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Good luck!
It also depends on the fork. The grade of stainless steel used for knives, something like a Wusthof, Dexter, or Victorinox will stick to a magnet. A carving fork made from this material, no problem. The stainless used for tableware is often not magnetic. Try a magnet on one of the matching pieces.
You may have to get a new fork.
Vaughan
Old 01-15-2013, 03:54 PM   #4
Lily&Me's Avatar
Normal , Illinois
Uh-oh. We've done this twice.
Haven't attempted to retrieve the utensil, doubt it has come out the other end but perhaps it has.
We have noticed no problems with emptying our tanks.
Maggie
Old 01-15-2013, 04:09 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
fishing for forks.... a new Airstream sport!
It might be possible for the fork to jam in the drain valve - and of course it would only happen if you're at a busy dump station - never in the privacy of a full hookup site.
If the forks are magnetic it shouldn't be too difficult to get it out, if not, one of those gizmos you use to retrieve screws from the innards of an engine might work. I'd drain AND bleach clean the tank to try to be able to see the fork, using wheel ramps to try to encourage it to move to a point where it was visible.
Of course having the tank that clean could be a prelude to pulling the toilet.
OR just fergitaboudit!
Paula
Old 01-15-2013, 04:23 PM   #6
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
Wet'n dry vac. with a long hose should do it......I'd drain and flush the tank first if it were me.
Del Gurney is offline   Reply With Quote
Old 01-15-2013, 04:24 PM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Thank you! Bert
As long as you don't discharge through a macerator pump, the fork is unlikely to do a lot of damage. It's longer than your slinky is wide, so if it does go down the drain, it should go one end first. but that's not likely to happen until you've moved your trailer a few times, and it bounces around inside the tank.
If you haven't moved your trailer, the fork should still be right below the toilet drain. A mechanic's flex grabber claw should be just the thing.
I carry one in my Airstream's tool kit for when I drop things in places I can't reach, but so far haven't needed to use it in the loo.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-15-2013, 04:29 PM   #8
Crusty's Avatar
1992 34' Excella
I wouldn't move the dump valve until I got the fork out of there somehow because there's just too big of a chance that the valve innards will catch the fork and make it so that you can't reclose it. You don't want to have to cut an opening in your bottom skin just so that you can disassemble the valve to get the fork out.
That's how my dumb luck usually seems to work anyway.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 01-15-2013, 04:51 PM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Once you find the fork clean it good before you use it.
Old 01-15-2013, 05:01 PM   #10
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 36
Don't Expect to Be Invited to the Next Pot Luck
... No, really. What are you concerned about? As Protagonist says, unless you are running sewage through a macerator pump you have a non-problem. Your dump valve is a huge, gate-valve. It has no innards. If the fork makes it that far and lodges, just reach in and take it out.
I would say you biggest problem will be people not wanting to eat your Swedish meatballs from now on.
Ken L
1966 Tradewind 24
2018 GMC Yukon XL Denali
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 01-15-2013, 05:02 PM   #11
Nah! Throw it away as a lost cause. But throw it away somewhere other than your toilet!
WBCCI #1105
TAC LA-4
Old 01-15-2013, 05:03 PM   #12
Alumaholic's Avatar
1966 24' Tradewind
Images: 36
On Second Thought...
Have your wife reach in and get it. She has smaller hands, and it was probably her dish water.
Ken L
1966 Tradewind 24
Old 01-15-2013, 05:25 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You should retrieve the fork. Especially if there are 90 degree el's in the waste water drain system. I doubt the fork would go around the corner, but you can bet the toilet paper will catch on it. Then you will have a real problem.
TG Twinkie is online now   Reply With Quote
Old 01-15-2013, 05:28 PM   #14
Lily&Me's Avatar
Normal , Illinois
I want one of those!
Maggie
