Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 07-16-2006, 09:54 AM   #1
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
fix those sewer vents!
hey gang,
here is an easy project that can prevent thousands of dollars of damage to your trailer!
john
you call them ferrets, i call them weasels.
Old 07-16-2006, 09:56 AM   #2
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
for less than 40 bucks and using a few common tools you can prevent the number one reason airstreams leak!
here is what i found under my sewer caps!
john
Name:	cover as found.jpg
ID:	23625   Click image for larger version
Name:	cracked gasket.jpg
Name:	second bad gasket.jpg
Old 07-16-2006, 10:02 AM   #3
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
after removing the covers and cleaning up the roof of the trailer it is time to install the new gasket and screen!
i like to use a cordless drill with a cupped brush ro remove the old vulkem. a gasket scraper and a knife also helps.
trimming the corners of the screen prevents the screws from catching it and possibly tearing it.
here is a shot of the cleaned up area with the new gasket and the vulkem getting squirted under the screen. this makes the majority of the seal!
Name:	cover removed.jpg
ID:	23628   Click image for larger version
Name:	sealing under gasket.jpg
Name:	sealing 2nd one.jpg
ID:	23630   Click image for larger version
Name:	trimming screen.jpg
Old 07-16-2006, 10:06 AM   #4
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
after a liberal amount of vulkem is under the screen and new gasket i flipped it down and made sure it oozed out all the way around to insure a good seal!
after that, just reinstall the cover with stainless screws if your trailer does not already have them as mine did.
to finish a bead of vulkem goes around the edge!
bam, done! less than 15 min each!
john
Name:	vulkem oozing out.jpg
Old 07-16-2006, 10:14 AM   #5
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
the finished vents, good for another 5 years!
john
Name:	vent 1 finished.jpg
ID:	23633   Click image for larger version
Name:	vent 2 finished.jpg
Old 07-16-2006, 11:14 AM   #6
FT RVing
lebolewis's Avatar
Profile:  1976 31' Sovereign
A place w/low Humidity , FT RVing, north & south
Ditto
Hey John......great photos. They look just like mine did. I resealed all three of them last week after I found a leak in one of them. Apparently it had been leaking for some time, undetected. I got the gasget material, 6" square rubber pieces, at Lowes in the plumbing dept and made the gasgets. I also found a lot of trash in each vent hood that blocked the drain holes. Soooooo....I used aluminun screen and formed it to seal the vent at rhe top and used a seam of vulkem to hold it up there. Now trash cannot get inside the vent hood!! Works great! Bill
lebolewis is offline   Reply With Quote
Old 07-16-2006, 11:23 AM   #7
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
good tip bill, i have seen folks make little aluminum deflectors that clip into the vent to deflect leaves. sorry i don't have a pic of that.
one small note about the drain holes, i have seen a number of 70's vintage trailers that do not have the holes. adding them would just take a couple of seconds with a drill when the cover is off.
btw, the materials for this project came from inland RV.
john
Old 07-16-2006, 06:02 PM   #8
Profile:  1972 25' Tradewind
Madison , Wisconsin
Thanks for the tip. Now I can add another item. # 137 : Check vents and screens!
Seriously though, thanks, I never thought of that one.
Smokin Camel is offline   Reply With Quote
Old 09-20-2006, 09:21 PM   #9
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Wow that will do it!
I don't even see any screen, the rubber must be shot!
If you saw the damage this caused...........
I can't post pic's anymore, don't know why?
The PO had this parked 6 years, he just let it rot around the bath down into the black tank compartment.
Should I get the factory gaskets or just get something from NAPA and make my own?
I had to cut a 30" x 48" section from the middle of the floor to repair it all.
Again all wet globbed up pink spongy insulation causing rust, cleaned it all out and will add new foil bubble R-14.
This is another reason to fiberglass these wood floors, if that was done no floor rot no rust no work.
But there was a silver lining to all this. ONe of the waste gates was leaking and I was going to take inspection covers off and try to rebuild the valves from below.
Now that I see it from the top it would not have been possible without a lot of grief.
Can I get rebuilding kits for the #1447 Thetford 3" valves.
If so where? how much$$$
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 09-20-2006, 10:03 PM   #10
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Mine doesn't have screen either - is this something they did at the factory or something people are doing aftermarket?
Fyrzowt is offline   Reply With Quote
Old 09-20-2006, 10:50 PM   #11
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
my buddy's 74 excella had a couple from the factory without any screens.
john
Old 09-21-2006, 07:23 AM   #12
FT RVing
lebolewis's Avatar
Screens
john
Hey John,
I've been meaning to bring this up since the last time I looked at your great "vent refurbishing photos". I could be wrong, but I think those fiberglass mesh pieces are supposed to go over the top of the vent pipe, sealing the opening to the aluminum housing, to keep the bugs, trash, etc out of there and to keep those little drain holes in bottom of the housing open. If that's not what they are for, then what useful purpose do they serve?
That's the way they were when I re-did my vents on my 76 Sovereign and they looked like they could have been the original stuff! I couldnt get the fiberglass stuff, so I used aluminum screen, formed it so it fit up in the top of the aluminum covers and "Vulkemed" it in place from the inside, flush with the top of the vent cover. Bug and trash sealed, but open. Bill
Old 09-21-2006, 08:38 AM   #13
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough , winter home Zavalla TX
Bill.. You are right on this one... fiberglass is supposed to go over the top.. been there and done that.. got instructions from Inland Andy when we ordered ours..
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30 (Costalotta)
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
Yamaha 3000
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 09-21-2006, 10:25 AM   #14
aztlanco's Avatar
Profile:  El Paso , Texas
Send a message via AIM to aztlanco
I did the same "screen" job on mine years ago when I detected a foul odor inside the trailer and outside. After a nose investigation, I found out it was coming from the vent and guess what???? It was blocked completely near the top of the pipe. I took a coat hanger wire and pulled out a dead bird that was decomposing and had gotten stuck in there (a friend told me they do that in winter to stay warm with their own body heat,, kind of like putting on a jacket). No more problems.
Ernie
'58 Traveler, 18ft.
aztlanco is offline   Reply With Quote
Sewer Hose length? Titu & Gail Waste Systems, Tanks & Totes 16 04-21-2004 02:39 PM
Gaskets, vents, etc... Chuck Windows & Screens 3 10-27-2002 03:18 PM
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 7 10-03-2002 02:06 PM
I want to connect permanently to local sewer Jaime Esparza Waste Systems, Tanks & Totes 1 09-09-2002 09:49 AM
wiring fix? ALANSD Airstream Motorhome Forums 9 06-20-2002 08:40 AM
