Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 06-27-2002, 08:36 AM   #1
Profile:
Finding water leaks
An easy way to find water leaks is with an air compressor. A air pressure regulator must be used. The regulator should be set at about 30 psi. The method I have used is to remove water heater drain plug. When water is drained, connect air hose to tank. The regulator is connected at the air compressor . A small ball valve and air pressure guage are connected at the water heater for convenience. When air is applied to tank, the water remaining in system will be exhausted as each valve is opened. Any connection with any leak can be detected. Loud radio noise is not helpful. All water systems can be checked. The gas system can also be checked with the same method.
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Pingbacks are On
Water Leaks? - New Repair Product COArgosy78 Plumbing - Systems & Fixtures 10 05-27-2008 01:22 AM
Water Leaks and Condensation-34' LTD lmcatee Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-04-2004 04:16 PM
New Owner (ignorance is NOT bliss!) water leaks 31ftINT'LSOV1974 Plumbing - Systems & Fixtures 11 08-06-2003 06:07 AM
Water leaks 53flyingcloud Our Community 2 11-28-2002 01:07 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
