Old 02-15-2015, 11:34 AM   #1
Airborne6's Avatar
2015 23' International
Lakeview , Arkansas
filtration
New to Airstream.
23D International on order. Question on the fresh water tank fill. The kitchen sink comes with an inline filter. Does anyone also filter the water as you fill your tank??? Recommendations?
Airborne6 is offline   Reply With Quote
Old 02-15-2015, 11:47 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I do, I use an external filter. I figure it will take out most of the contamination and make the internal filter last longer.
MICHAEL
Old 02-15-2015, 12:01 PM   #3
Airborne6's Avatar
Lakeview , Arkansas
Thank you Michael. Makes since to me.
Dave
Old 02-15-2015, 12:37 PM   #4
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
I use a Culligan inline filter for filling the tank and on the inlet.
Its a charcoal filter and does a great job on minerals. When in transit I let it air dry then flush before connecting to the trailer . I replace it every season.
Name:	13 side comp.jpg
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 02-15-2015, 06:17 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
We took our "under the sink" filter out. I think Airstream installed one as a low cost amenity and sales point. Mine was a nuisance to change and got in the way during winterization. (There was a couple pints of antifreeze in the filter bowl.)
I think filtering the incoming water to the trailer is the way to go. But I don't even do that. This is one of the few places in the world where clean drinking water is available at almost every source.
David
Old 02-16-2015, 10:25 AM   #6
2007 27' Classic FB
Ridgefield , Washington
We use the Tastepure water filter and the under sink filter as well. We just feel you can't be too careful on the road.
John & Lisa
Woosch is offline   Reply With Quote
Old 02-16-2015, 10:52 AM   #7
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I use an inline filter at hookups, but I do not use a charcoal filter when I fill the tank. Here's why:
A charcoal filter removes chlorine. A small chlorine residual in your fresh water tank will help to keep slime from growing over time. If you take out the chlorine, you'll eventually get bacterial growth and slime in the tank - which I do not care to drink.
Reference.
Old 02-16-2015, 11:55 AM   #8
Glenritas's Avatar
1969 25' Tradewind
Reference.
This is why one would drain and sanitize the fresh water system .
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 02-16-2015, 12:06 PM   #9
Glenritas's Avatar
1969 25' Tradewind
David
You'd be surprised at how much mineral content is in a lot of campgrounds and RV Parks.
By air drying the filer it will cause the iron to rust . When you purge the filter at the next stop it will be flushed out as rusty looking water.
Sure beats having it in your system and settling in the water heater , staining your sinks and leaving hard water spots.
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 02-17-2015, 05:54 AM   #10
Airborne6's Avatar
Lakeview , Arkansas
Thank you all for your input. This gives me the knowledge to test and eventually settle on a method that works for us. D&L
Some days your the bug.
Some days your the windshield.
WBCCI # 1959
Black 2015 Toyota Tundra TRD Pro CrewMax
2015 23D International Signature (Salsa)
Stella our Bull Pointer mix
Under sink filtration Rust Fresh Water Systems 5 09-27-2013 07:51 AM
Water Filtration System for Drinking Water kentuvman Fresh Water Systems 6 02-11-2013 08:34 PM
Boondocking gray water disposal and filtration Boondocker Boondocking 18 02-25-2010 09:20 PM
Reverse Osmosis water filtration ncbambi Water Heaters, Filters & Pumps 8 01-26-2010 09:37 AM
Water filtration system Devoman Our Community 7 08-18-2005 06:48 PM
