Old 08-24-2017, 04:41 AM   #1
Sometime , Alabama
External Water Filter Carrier - Housing
I found the picture below in the RVshare blog.
http://blog.rvshare.com/choosing-bes...ter-need-know/
Have any of you fabricated or purchased a carrier/housing for external water filters that you really like?
If so, please share your setup and ideas.
bigcountry is offline   Reply With Quote
Old 08-24-2017, 08:53 AM   #2
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
Saw one this past weekend made from a plastic step stool. It was a single canister and they simply cut a hole in the top of the stool that the canister dropped right into. Wish I had snapped a picture of it.
1973Argosy is offline   Reply With Quote
Old 08-24-2017, 09:36 AM   #3
richw46's Avatar
Lexington , Kentucky
I just have a heavy wire hooked to each side of the inlet/outlet and I hang it on the spigot or post, one less thing to store and carry around. I found these ideas.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-25-2017, 03:59 AM   #4
Sometime , Alabama
Thanks for the replies!!
Old 08-25-2017, 06:43 PM   #5
1970 23' Safari
Torrance , California
I like the looks of the two pictured and they look "made by owner" which is even better.
When I bought my two canister system from RV filters they suggested a large plastic tote with a lid. Cut two holes for the in/out hose and keep it under the trailer when in use out of the sun. The idea was to keep things from growing int he canisters.
I did not have time before my recent trip to Canada to put the holes in the tote and wound up storing my water hose in the tote with the filters. Everything was a "little" to tall for the lid to stay on without a bungee cord during travel, but what I was able to do was use the bungee to hold the lid on with the in/out hoses coming out under the lid which I held on with the travel bungee. It is now stored for travel in the bed of the truck and I no longer need to worry about a wet hose in the storage compartment on the trailer.
1970 Safari is offline   Reply With Quote
Old 08-26-2017, 11:36 AM   #6
Something Shiny
2017 27' International
Mosinee , Wisconsin
Followup question regarding filter storage
I'm new at water filtration and would like to pick the brains of those more experienced. I used the 2-filter external system for the first time, but do not expect to make use of it again for some time, as clean water will be readily available on our remaining trips this year.
My question relates to how best to store the filters when not in use? Should I drain and dry them or simply allow them to remain filled?
Mark & Gina
2017 International Serenity
160W Solar roof mount + 160W Zamp portable
ProPride hitch, 1400#
2015 GMC Denali 1500
Pongo is offline   Reply With Quote
Old 08-26-2017, 02:29 PM   #7
richw46's Avatar
I have a single GE water filter on ours. When we move I just disconnect and drain both sides, then I close the valve on the outlet side.
I don't understand the need for 2 filters. Wherever we go I see either a GE like mine or a filter that looks like a pill, blue or white. We have clean drinking water in all of the campgrounds and state parks in the US. If it wasn't, I wouldn't be putting it into my AS lines or water tank (or me).
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-26-2017, 02:37 PM   #8
1974 27' Overlander
Baltimore , Maryland
Depends on what kind of filters they are, but absent manufacturer's instructions to the contrary, sanitize them with bleach, remove water, and store open and dry when you're not using them.
If you're on an extended trip and using it periodically, store wet and flush before each use. Re-sanitize and flush after sitting for a while, or if you ever suspect a questionable water supply. Trash filters and clean/sanitize the housing if sliminess or odor develops.
As a side note, never take the first draw from a fixture. The worst bacteria and metal contamination are in the first few seconds. Run the water til it's cold, then use.
1974 Overlander In Progress
TheGreatleys is offline   Reply With Quote
Will paper air filter change dynamics of engine with K&N filter? Astrodokk Mechanics Corner - Engines, Transmission & More... 23 09-05-2016 02:24 PM
LY 94 30 Marquis 5000 air filter housing runter Land Yacht/Legacy Motorhomes 6 06-20-2016 05:55 PM
Repair water filter housing? dolphin44 General Repair Forum 8 04-14-2014 07:55 PM
Water in marker light housing danlehosky General Repair Forum 1 05-13-2012 06:27 AM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
