Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 05-10-2008, 07:44 PM   #1
Dooley
Dooley's Avatar
Profile:  1987 23' Sovereign
Ft. Worth , Texas
Extended Storage and Water System.
My TT has been in storage for the past 9 months and will probably not be used for another 9 months. I winterized the water system before storage and I am thinking of just leaving the antifreeze in the pipes till I use it. Do you see any problem with letting antifreeze sit in the pipes that long?
Dooley is offline   Reply With Quote
Old 05-10-2008, 09:47 PM   #2
2airishuman
2airishuman's Avatar
Profile:
hi dooley...
would that be 18 months total with antifreeze in the pipes ?
that is a LONG time.
the stuff does evaporate and the residue will be dissolving out of the pipes and into the water for a LONG time too.
the other options are...
-drain the lines, rinse and flush them with air. then leave them empty, but some folks think dry lines are prone to failure.
-drain the antifreeze and run water though the lines, until next winter, then antifreeze 'em again.
regardless of what u do there may be some drips and leaks after such a long time without use.
i'd ditch the antifreeze, flush em out really well with water, and then blow air through the lines...
what are u gonna do with the tanks and traps and drain lines?
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 05-11-2008, 04:26 AM   #3
62overlander
not the shiniest rivet
62overlander's Avatar
Profile:  1962 26' Overlander
Catonsville , Maryland
anti- freeze in Texas? Is it to keep the pipes from over heating? Nine months from now will be winter again, or summer again if you live in Texas.
read my blog at: http://annalumanum.blogspot.com/ or view my photos at: http://picasaweb.google.com/dadofava1966/AnnaLumanum02
WBCCI, VAC, WDCU#7183
62overlander is offline   Reply With Quote
Old 05-11-2008, 04:29 AM   #4
utee94
Profile:  1963 26' Overlander
I think it froze once here in Austin...
Old 05-11-2008, 10:01 AM   #5
Dooley
Dooley's Avatar
Ft. Worth , Texas
Originally Posted by 2airishuman
hi dooley...
cheers
2air'
That is what I was worried about, the time peroid with that old stuff in there.
I'll just flush with water then re antinfreeze in the Fall as you suggest.
I always pour antifreeze in the traps and don't generally do anything with the tanks except to flush and clean them very well after each use and before storage. Thanks for the advice.
Old 05-11-2008, 10:11 AM   #6
Dooley
Dooley's Avatar
Ft. Worth , Texas
Ha, ha! I live in North Texas. When the pool ices over and the dog is walking on the ice you know your not that close to Mexico. But in the summer, I swear we are right on the border.
Old 05-11-2008, 10:25 AM   #7
Dooley
Dooley's Avatar
Ft. Worth , Texas
But you really aren't sure, right?
If I lived in Austin, I probably wouldn't think about it much either. From what I can tell Austin looks to be about the best area in Texas to live in and the location is about perfect to drive to anyplace in the Southwest US.
Old 05-11-2008, 03:34 PM   #8
Dan4odm
Commercial Vendor
Dan4odm's Avatar
Profile:  Currently Looking...
Colfax , North Carolina
It should be fine
No
Dan4odm is offline   Reply With Quote
Tutorial on water system? davida Fresh Water Systems 12 05-28-2007 12:38 PM
Need a little help with my water system please!!! jayk47 Plumbing - Systems & Fixtures 2 02-24-2007 09:46 AM
Water Filter System andyfuson 2004 International CCD 4 06-02-2004 08:42 PM
Bringing a Plumbing System out of Long Term Storage 66Overlander Plumbing - Systems & Fixtures 5 05-18-2004 07:47 AM
water system question Alex Water Heaters, Filters & Pumps 1 01-17-2004 02:20 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
