hi dooley...
would that be 18 months total with antifreeze in the pipes ?
that is a LONG time.
the stuff does evaporate and the residue will be dissolving out of the pipes and into the water for a LONG time too.
the other options are...
-drain the lines, rinse and flush them with air. then leave them empty, but some folks think dry lines are prone to failure.
-drain the antifreeze and run water though the lines, until next winter, then antifreeze 'em again.
regardless of what u do there may be some drips and leaks after such a long time without use.
i'd ditch the antifreeze, flush em out really well with water, and then blow air through the lines...
what are u gonna do with the tanks and traps and drain lines?
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
