Old 06-02-2015, 08:20 AM   #1
tarh2o's Avatar
1975 25' Tradewind
Boerne , Texas
Electric Tankless Water Heater
I've been crawling the site and everyone has big praise for the precisiontemp propane water heater. Eventually I will get one of these for my airstream once I renovate it completely for full time living. I will get the floor vented model to preserve the exterior look of my wonderful 'stream.
In the interim I was looking at a tankless electric water heater and wondered if anyone had any experience with the electric variety. I am only looking to either run my shower or my sink faucet with this one (separately) and I will always be hooked to shore power (30AMP). I've found this one that is all electric and rated at 120v@30amps - Instant-Flow Tankless Instant Water Heater SR - Chronomite. The model I am looking at is the SR-30L/120.
If I hook this up and want to take a shower AND run the AC will this blow the breaker? I'm a little concerned that it will draw too much and I wont be able to run both.
As always any advice will be most appreciated.
TARH2O
1975 25' Airstream TradeWind International - Under Renovation
2012 MB ML350 BlueTec
tarh2o is offline   Reply With Quote
Old 06-02-2015, 08:43 AM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Electric tankless water heaters use a lot of power. 30 amps is all you have for the trailer. The air conditioner is going to draw 14 to 15 of that when running and a lot more when starting up. That probably does not leave enough for the water heater.
I've been told that most of the smaller electric tankless units are intended to serve one sink for hand washing and not much more. Don't know if this one would be adequate for a shower.
Electric power management is kinda like a budget (with no credit card). Every unit you turn on counts as spending. When the total gets too high, the breaker (or is that the banker?) puts a stop to the spending.
Old 06-02-2015, 08:51 AM   #3
tarh2o's Avatar
1975 25' Tradewind
Boerne , Texas
Unfortunately I think you are correct. There is just not enough power to operate the AC and the WH.
Consequently I have found a great compromise with The PrecisionTemp TwinTemp Jr that will heat my water AND the airstream in those chilly winter months. Only downside is that they are very costly and require a good amount of space to plumb it in.
Guess I will have to just keep the little Airtron 4.5 WH until I renovate the entire airstream.
TARH2O
Old 06-02-2015, 09:04 AM   #4
1966 22' Safari
Weatherford , Texas
We installed the Precision Temp 500 several years ago. Doesn't heat the trailer, but it does a fantastic job heating the water and uses very little propane.
BTW, a small electric space heater (carefully located with fire prevention in mind) does a great job of heating our Airstream. Electric power is usually part of the campground fee and I've paid for that anyway. Propane is on me.
1500 watt heater is 12 to 13 amps, so about half our power budget. Just watch out for the microwave and the hair dryer at the same time.
Old 06-02-2015, 12:51 PM   #5
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Good for home, not for AS
We use tankless in our home. Tankless heaters are usually rated by their ability to raise the temperature (in degrees F) of a specific volume of water flow (e.g. 1.5 Gal per min). Each of ours requires a 50 amp dedicated 220v circuit to achieve enough temperature increase at typical shower flow rates to take a hot shower. And we are starting with warm inflow water (our cold water at this time of year arrives at the house at 80 degrees F). I think our units are 40 degrees F at 1.5 or 2 GPM.
Based on my experience at home, I think the other posters are right... given sometimes cold inflow water at campsites, the flow rate of even a handheld shower and the electricity required to make a shower comfortable I think this isn't the right solution for the AS world.
GammaDog is offline   Reply With Quote
Old 06-02-2015, 09:52 PM   #6
Wolf Alaska's Avatar
Madison , Alabama
A point to consider, using 30 amps puts a strain on every connection & the 30 amp cord. I lost a fairly new twist lock 30 amp cord in March. Burned where it connects to RV. Had been pulling 20 to 30 amps most of the recent time...electric fireplace, electric water heater, MW, coffee maker. I'm using more dielectric grease to try to minimize corrosion & arcing on the new cord. BTW, when U lose U R 30 amp cord @ 6 PM, U R out of electricity until tomorrow when U can make the 110 mile round trip to nearest source for replacement. It was the A/S dealer in Defuniac Springs, Dixie RV. I turned the burned cord into a 26' 30 amp extension cord
Let's Roll !
Wolf
Wolf Alaska
M.S./CFI/IR/ME/CP
FMCA SKP GS GPAA NRA USN (Ret)
Wolf Alaska is offline   Reply With Quote
Old 06-03-2015, 09:21 AM   #7
Floatingair's Avatar
1994 30' Excella
Kiefer , Oklahoma
Floating air here. I use a 1500w flat wall panel. They take up no floor space.
Floatingair is offline   Reply With Quote
Old 06-03-2015, 01:10 PM   #8
tarh2o's Avatar
1975 25' Tradewind
Boerne , Texas
Thanks to all for the feedback. With my current intent for the AS in the future I definitely will be using the PrecisionTemp TwinTemp Jr. I plan to boondock a bunch living on the BLM parks and on free sites I can find so limiting my electric consumption and water use will be a priority.
I'm already without a microwave (even in my home now) so my only large electric draw will be my computer/TV and the AC. My fridge, hot water and heater can run on propane so I should be able to go for a week or two depending on water and propane.
TARH2O
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
Help choosing an all electric tankless hot water heater Projecttinca Plumbing - Systems & Fixtures 3 03-25-2013 08:35 PM
Tankless water heater FC54 Water Heaters, Filters & Pumps 20 10-27-2004 03:18 PM
tankless hot water heater imeynstein Water Heaters, Filters & Pumps 19 04-17-2004 01:58 PM
Tankless water heater spinolio Water Heaters, Filters & Pumps 3 12-21-2002 09:53 PM
