Old 11-28-2006, 11:11 PM   #1
1973 23' Safari
Meadow Vista , California
Electric drain valves
[Has anyone installed an electric Drain Master Valve in a 1973 l/y?
Walt Riley Meadow Vista CA
Walt74wra8 is offline   Reply With Quote
Old 11-28-2006, 11:52 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
No, my drain valves in my '72 are easy to access and work well manually.
The main reason for my reply was to welcome you to the forums. As you may have already seen, there is a ton of info here. Welcome aboard!
Dave
Fyrzowt is offline   Reply With Quote
Old 11-29-2006, 04:04 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I would be hesitant to install an electric drain valve. I have had times where something gets stuck at the valve trying to leave the tank. I can feel it when I try to close the valve. If I had an electric one I may not know it and break the valve when I try to close it.
Michelle TAC MT-0
Sarah, Snowball
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
