Old 09-04-2014, 03:29 PM   #1
danjoe91's Avatar
1985 32' Excella
Valley Village , California
Images: 16
Dump valve leak
I seem to have a leak in what I am sure is the valve labeled 'Main'. Although the tanks are empty now, I would get a slow drip from the (new) cap. It appears I also need a new white connector fitting as that drips as well. Replacing/ repairing these valves looks like I must remove that huge underbelly pan cover. Has anyone ever added a new valve outside of that near the existing levers? I'm not sure if cutting the 3" ABS behind the levers would work, or somehow out on the end. I would not know how I could do this without blocking those levers, or reducing my ground clearance by angling the new valve away from them.
Name:	Airstream dumpvalve leak.jpg
danjoe91 is offline   Reply With Quote
Dump Valve Leak! Ideas? pamelake Waste Systems, Tanks & Totes 5 05-30-2006 08:01 PM
Dump Valve Leak David Hall Waste Systems, Tanks & Totes 8 02-17-2004 05:26 PM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
Dump Valve Will Not Open Darryl Waste Systems, Tanks & Totes 1 06-19-2002 12:19 PM
Dump valve gwsullivan Waste Systems, Tanks & Totes 11 05-30-2002 08:38 AM
