Old 11-04-2019, 01:18 PM   #1
2015 30' FB FC Bunk
Baton Rouge , Louisiana
Dump Mechanism - 2015 Flying Cloud 30 Bunk
Would someone mind posting an exterior picture of the drain mechanism for the black and gray water tanks?
We had the rear left hand side (facing forward towards the tow vehicle) tire blow out/come apart. It damaged the wheel well trim, the underbelly (behind the tire) and the drain.
I'm having a bit of trouble figuring out all that was damaged and is now missing...
Thanks!!!
ID:	355612   Click image for larger version
andyvignes is offline   Reply With Quote
Old 11-04-2019, 01:24 PM   #2
2017 27' Flying Cloud
Fort Worth , Texas
How’s this? 2017 FC 27’
billrector is offline   Reply With Quote
Old 11-04-2019, 06:28 PM   #3
Fort Worth , Texas
Thanks!!!
Hopefully the picture is what you needed. Sorry you have to deal with this. Two suggestions:
1). If you have the Marathon tires, get rid of them
2). Get a TPMS (Tire Pressure Monitoring System). If will inform you if tire pressure is getting low or you have a blowout.
Old 11-05-2019, 04:18 AM   #4
2015 30' FB FC Bunk
Thanks so much - I really appreciate your response!
Old 11-05-2019, 06:08 AM   #5
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Yep, like Bill said. The Goodyear “China Bomb” Explodathons are more headache than they are worth.
The New Goodyear Endurance is turning out to be a good tire or go with the tride and true Michelin LTX
GMFL is online now   Reply With Quote
Old 11-05-2019, 01:22 PM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Quick list:
You lost both dump handles and likely damaged the rods / mounts that connect to them. ( = all that needs to be replaced. You also lost the final valve on the outflow if your trailer had one.
It would be a really good idea to poke a bit at the drain plumbing, it likely took a hit as well ....
uncle_bob is online now   Reply With Quote
Old 11-05-2019, 08:09 PM   #7
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
My 2014 bunk doesn't have that 3rd valve. I'm guessing 2015 didnt either.
Hi
Quick list:
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 11-06-2019, 06:34 AM   #8
Fort Worth , Texas
If you are talking about the valve in front, in between the other two valves, that is an aftermarket add-on.
Old 11-06-2019, 08:58 AM   #9
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
How old were them tires?..
2015 Flying Cloud, Rear Bunk, Subfloor Damage/Soft Spot MichaelSTR Repairing/Replacing Floor &/or Frame 5 10-09-2019 02:05 PM
Flying Cloud :: 2015 Airstream Flying Cloud Poiny Airstream Registry Discussions 0 05-24-2017 12:39 PM
Flying Cloud 30Fb Bunk - Walk Through on 2015 Model - Colonial Airstream Colonial Airstream Commercial Listings 8 06-29-2016 01:47 PM
2015 GMC Yukon Denali 4WD & 2015 Flying Cloud 30 ? DHart Towing, Tow Vehicles & Hitches 22 04-09-2015 08:01 AM
