Old 10-29-2015, 05:27 PM   #1
PSU1981
2015 27' Flying Cloud
Spring , Texas
Draining Fresh H2O Tank
Just Sanitized the fresh H2O tank & now draining - my FC 27FB 2015 has the white poly drain & 2 brass ones - can I use all 3 or do I just have to use the white one - that's taking forever.
Glenn
PSU1981 is offline   Reply With Quote
Old 10-29-2015, 05:33 PM   #2
Long Island , New York
Have you checked your owners manual? You might also want to read the following thread FYI, although it concerns a different model than yours:
http://www.airforums.com/forums/f516...ns-142643.html
The brass drains are probably for low points in the water lines, which you definitely should also drain IMO, among other winterization tasks per AS.
The following sub-forum also has many other threads on-topic:
http://www.airforums.com/forums/f458/
Old 10-29-2015, 05:47 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Opening a sink valve will help the water drain a little quicker.
MICHAEL
Old 10-30-2015, 08:33 AM   #4
PSU1981
Spring , Texas
What is a sink valve ? Do you mean just run H2O from the sink?
Old 10-30-2015, 08:45 AM   #5
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Right, just open any faucet to act as a vent.
Larry
lsbrodsky is offline   Reply With Quote
Old 10-30-2015, 08:46 AM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
Opening a faucet will prevent vacuum from trying to hold in the water you are trying to drain from the brass low point valves.
CRH is offline   Reply With Quote
Old 10-30-2015, 09:11 AM   #7
You should open all faucets, assuming you are actually starting to winterize the coach fully (not just the fresh water tank). Your owners manual should list all the gravity-drain steps to take, followed up by compressed air, removing HW heater drain plug, etc.
Open all hot and cold faucets:
-- galley sink
-- bath lavatory sink faucet
-- bath hand shower
-- outdoor shower
-- toilet flush valve and hand sprayer if so equipped
-- hot water heater pressure relief safety valve stem
-- etc..
Have you checked your owners manual and the various other winterization threads I linked for you earlier?
Old 10-30-2015, 09:13 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The two brass valves are for the hot and cold water lines. The plastic valve is for the water storage tank. I drain them all and leave them open whenever there is a chance of a hard freeze, even if camping over night or towing when the temperatures go well below freezing for several hours.
Doug and Cheryl
Old 10-30-2015, 09:39 AM   #9
Ditto to doug's advice.
Doug do you have tank heaters? My old coach did not, so I am unsure how much protection they afford. Thanks for any advice you can offer.
Peter
Old 10-30-2015, 10:13 AM   #10
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Open all three valves and open bathroom sink faucet to hot and it should drain hot water tank ...you're good to go..
Old 10-30-2015, 10:13 AM   #11
1961 22' Safari
Collegeville , Pennsylvania
Maybe it's just me, but I don't think opening a sink valve will help the FW tank drain. The sinks are all on the other side of the FW pump - so no air or water will go from the downstream devices back upstream to the FW tank. There's a check valve in the way.
To break the vacuum you would / should open the FW tank fill... assuming the fill isn't always vented.
The open sink valves (and shower) will definitely help with draining the hot and cold lines though.
No?
TheHandyDan is offline   Reply With Quote
Old 10-30-2015, 10:42 AM   #12
mandolindave's Avatar
What he said
I second what Handy Dan said
mandolindave is offline   Reply With Quote
Old 10-30-2015, 10:42 AM   #13
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
No?
TheHandyDan gets the prize for the correct answer! While there is no harm in opening the sink faucets in the trailer while draining the fresh water tank, the check valve in the pump (if functioning properly) should not allow any air back in the tank. Fortunately, on the year AS the OP has, there is a vent for the fresh water tank adjacent to the fresh water fill opening. So assuming that the vent is not blocked, opening the white drain valve should drain the FW tank. And it can take a very long time to drain all 39 gallons of water!
The two brass valves are the low point water drains and should also be open to drain the water system prior to winterizing. I'm not 100% sure how the system is plumbed, but it would probably be a good idea to open the faucets inside the trailer when opening the low water drain valves.
Bob Martel
WBCCI# 5766
Old 10-30-2015, 10:46 AM   #14
Actually you are all so very very wrong
The quickest way to drain the fresh water tank is to have my eldest daughter take a shower. ( just one shower )
Fresh H2O Tank Location Hans627 LP Gas, Piping, Tanks & Regulators 1 07-09-2015 09:39 AM
Fresh water tank filling when hooked to city H2O. OffTheCouch Plumbing - Systems & Fixtures 3 04-20-2015 05:13 PM
H2O heater, H2O pump, and winterizing the ponz Winterizing, Storage, Carports & Covers 1 10-19-2005 03:25 PM
Fresh H2O Tank Size?? RiskIt Fresh Water Systems 6 05-16-2005 01:23 PM
H2o leak from below (hot H2O tank ?) bigwoody Water Heaters, Filters & Pumps 3 09-27-2003 06:57 PM
