Old 08-22-2013, 05:18 AM   #1
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
Disconnecting Shower Drain ?
I started my bathroom reno last night, Sink and shower walls are out.
How do I disconnect the shower drain, does it disconnect from under the trailer?
My reno includes replacing the black and grey tank valves so I will be starting to remove the belly pan Saturday anyway.
Thanks for your help!
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
AldeanFan is offline   Reply With Quote
Old 10-08-2013, 07:14 PM   #2
Smokeydog's Avatar
Gonzalez , Florida
Look at the front of the shower. My Avion had a access panel. 4 screws and you could access the bottom of the shower.
Smokeydog is offline   Reply With Quote
Old 10-08-2013, 08:41 PM   #3
1977 Argosy 24
Milltown , Wisconsin
The shower drain on most trailers unscrews. Put a pliers down into the drain and engage the "X" in the bottom. Then unscrew the "X" and drain out of the ABS trap fitting.
ventport is offline   Reply With Quote
Old 10-09-2013, 04:55 PM   #4
1972 27' Overlander
Denver , North Carolina
There is also a drain wrench you could purchase at the big box store.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
