Old 11-24-2007, 09:15 AM   #1
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Custom holding tanks
I think I've been to every web site there is that has pre-made holding tanks and I still can't find the size that I need. Has anybody done the legwork already to find the company that isn't going to rip my lips off to have a custom tank made.
Old 11-24-2007, 09:30 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
My lips are still attached...although the custom tanks cost about $400-500 a piece not including shipping. Not too bad - a "standard" black tank for our '64 GT would cost about $450 too...
Custom Holdng Tanks
All-Rite tanks
Let me (or Mr.InsideOut) know if you need any additional info.
Shari
Old 11-24-2007, 09:41 AM   #3
A custom tank means a custom mold. Rotational molding of plastic tanks, within itself, is not a big deal. But to make sure the plastic powders and then the molten plastic don't sling all over the place, is another matter.
Your black tank is available.
What size are you looking for, I assume, a gray or water tank?
Old 11-24-2007, 09:53 AM   #4
Aerowood's Avatar
Arvada , Colorado
I'm looking for two tanks that will be plumbed together separated by a cross member. Both will be of equal size at 52" X 21" X 4". I want all the tanks and plumbing within the confines of the belly pan.
Kip
Old 11-24-2007, 10:03 AM   #5
InsideOut's Avatar
1956 22' Safari
Images: 108
Kip
That's what we are doing with the grey water tanks shown above. The black tank (the curved one) will sit above the floor.
Shari
Old 11-24-2007, 10:11 AM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I considered replacing my fresh water tank and was seeing prices in the $400 to $500 range as well. (It turns out, mine didn't need replacing thanks to a great tip from Chuck). At any rate, I found that I could have a stainless steel tank custom made by a local shop for about the same money.
With your wonderful skills, could you make your own? (Stainless, that is)
www.nesa.org
Air No. 6427
Old 11-24-2007, 10:24 AM   #7
Aerowood's Avatar
Arvada , Colorado
We are forbid to weld in our hanger by local codes, plus I don't have access to a tig welder to even do it at home. It didn't even occur to me bend one up out of stainless and take it to a local shop to weld up. I'll have to check out stainless prices. Thanks for planting the seed.
Old 11-24-2007, 10:31 AM   #8
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
how about 5052 X .063?
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 11-24-2007, 12:13 PM   #9
Aerowood's Avatar
Arvada , Colorado
5052 or 6061 would both work. I"ll need to price them both out
Kip
Old 11-24-2007, 04:00 PM   #10
InsideOut's Avatar
1956 22' Safari
Images: 108
Not necessarily...ours are 1/4" sheets of polypropolene with heat welded seams, not molded.
Shari
Old 11-24-2007, 04:24 PM   #11
Aerowood's Avatar
Arvada , Colorado
Shari, I haven't seen an update on yours in awhile, how's it progressing. I also don't see a toilet mounting flange on your black tack. Are you waiting on a final fit before it's added, and how is it installed?
Old 11-24-2007, 04:31 PM   #12
InsideOut's Avatar
1956 22' Safari
Images: 108
That's cuz there's no real updates...
Since you were here, we had a slab poured and built our gates for the back. Then had a few "house projects" we had to take care of and Mr.InsideOut sprained his back and has been flat on his back (or should be!) and on meds for about two weeks now. We have the welder coming next Saturday, to fix the step, add an outrigger and replace the rear cross member. Then we will be back to rockin' & rollin'....everything(?) from there on out we will do ourselves. Kinda disappointed we weren't abe to take advantage of this long weekend...oh well! Nothing to do until the welding is done and he couldn't fit us in until the 1st. We are having Bart from Timeless Travel come by & do it...he ought to know what he's doing, you think? Worth the wait ~
Yep, we waited on the toilet flange until we can get an exact location...there is someplace here in town that will add it, but I don't recall the name right now. I think it is friction welded in place...either that or "magic".
Oh yeah, we brought Maxwell home this afternoon, but it's getting dark, so we'll park him tomorrow...first time in a tight spot with both of them back there & we don't want to be rushed.
Shari
Old 11-24-2007, 08:01 PM   #13
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
You could also use one of these...
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 11-24-2007, 11:32 PM   #14
InsideOut's Avatar
1956 22' Safari
Images: 108
What is it and where do you get it?
Shari
Holding tanks eddo 1969 - 1973 Safari 8 07-01-2014 03:47 PM
When do they start having holding tanks? stellalaluna Plumbing - Systems & Fixtures 21 08-26-2007 02:55 PM
Holding Tanks achip Waste Systems, Tanks & Totes 1 06-18-2006 05:28 PM
Holding tanks, need help twilder Waste Systems, Tanks & Totes 2 07-18-2003 04:02 PM
Holding tanks smallfry Waste Systems, Tanks & Totes 2 12-17-2002 02:17 PM
