Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 11-25-2007, 05:12 AM   #15
byamcaravanner
byamcaravanner's Avatar
Profile:  1967 28' Ambassador
1963 19' Globetrotter
Waukesha , Wisconsin
Originally Posted by InsideOut
What is it and where do you get it?
Shari
It's a rubber grommet. You just cut or drill the correct size hole anywhere on the top of the tank and "muscle" the bottom flange of the grommet through the hole. I bought mine HERE, but I'm sure you could get them from most anyone that sells these tanks. They are available to fit 1 1/2", 2" and 3" pipe. They run between $5-$10.
Steve & the crew
'67 Ambassador International Twin
'63 19' Globetrotter
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 11-25-2007, 09:02 AM   #16
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Al holding tank?
Originally Posted by doorgunner
how about 5052 X .063?
An Aluminum holding tank? What are you goign to coat the inside so it does not corrode? For that matter what are you going to coat the outside?
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 11-25-2007, 09:03 AM   #17
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Cool! Thanks...I'll pass it by the Mr.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 11-25-2007, 06:03 PM   #18
steve hughes
Profile:  1970 25' Caravanner
Rutherfordton , North Carolina
I have broken off the same flange that connectes the comode to the black water tank. Can this be used to repaire my tank?
steve hughes is offline   Reply With Quote
Old 11-26-2007, 05:06 AM   #19
byamcaravanner
I sure don't see why not... give the folks at PPL a call. They were very helpful when I ordered my tanks.
Steve & the crew
Old 11-26-2007, 06:46 AM   #20
nsteel
Profile:  2007 27' Classic FB
Havelock , North Carolina
Ronco will make any tank with fittings where ever you want them at a very reasonable price. I had two holding tanks made to fit under the side decks of my trawler. I sent them a sketch, they sent me back a price with the sketch and they were perfect. RV Water Holding and Water Tanks - Ronco Plastics
They may also have a stock tank that fits your needs in their online catalog.
Phil
nsteel is offline   Reply With Quote
Old 01-13-2008, 08:13 AM   #21
rangebowdrie
Profile:  1971 25' Caravanner
scappoose , Oregon
I too, have used tanks by Ronco Plastics. They are very good quality, and can be made in just about any shape and size imaginable. Fittings of whatever size and placement you require.Have been to the factory, it's pretty impressive to see the moulding machines at work.
rangebowdrie is offline   Reply With Quote
Old 01-22-2008, 09:15 AM   #22
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
neutral
Michele; from one tail wheel pilot to another-
My urologist says ther should not be a problem here,the tank will outlast me if flushed regularly.
I could coat it with some epoxy, or better yet I would just build a new tank of carbon. I was merely offering up idea's to another member.
Maybe your obgyn can shed some light on female fluids and how they attack aluminum. I'm not worried in the least.
But then again that coming from someone with a non-corrosive personality.
DG
The 2 worst things that can happen to an old aviator:
(1) One day you will walk out to your aircraft,
knowing that it will be your last flight.
(2) One day you will walk out to your aircraft,
not knowing it will be your last flight.
Proud Appellation American
doorgunner is offline   Reply With Quote
When do they start having holding tanks? stellalaluna Plumbing - Systems & Fixtures 21 08-26-2007 02:55 PM
Holding Tanks achip Waste Systems, Tanks & Totes 1 06-18-2006 05:28 PM
Holding tanks eddo 1969 - 1973 Safari 6 09-13-2005 09:06 PM
Holding tanks, need help twilder Waste Systems, Tanks & Totes 2 07-18-2003 04:02 PM
Holding tanks smallfry Waste Systems, Tanks & Totes 2 12-17-2002 02:17 PM
