Old 04-08-2016, 08:08 PM   #1
57Vintage's Avatar
1957 26' Overlander
Battle Ground , Washington
Images: 21
Cunningham P trap
Getting my 57 Overlander stripped down to do a shell off and found this P trap under the shower drain. It also had a brass one way valve down stream. The valve is just a flapper with no seal or spring tension. Any one have any experience with this shallow P trap? Wouldn't mind installing in the new shower/bath tub we'll install.
57Vintage is offline   Reply With Quote
Old 04-14-2016, 10:05 AM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Wow that interesting! If you not putting that back in, check out the hepvo valves they eliminate the p-traps and free up more room.
Matt
rugjenkins is offline   Reply With Quote
Old 04-14-2016, 11:51 AM   #3
1972 27' Overlander
Denver , North Carolina
I used Hepos in my Reno and love that I didn't have to cut another hole I the floor
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 04-14-2016, 12:55 PM   #4
1972 27' Overlander
Old 04-14-2016, 01:08 PM   #5
Images: 59
I reinstalled mine. I replaced the flapper check valve with a new one because I was running forward to a new gray tank and I didn't want water sloshing back into the shower pan every time I accelerated. It doesn't need to seal tight, just prevent mass flow in the opposite direction.
Has worked fine.
Old 04-14-2016, 11:27 PM   #6
57Vintage's Avatar
1957 26' Overlander
Images: 21
Thanks guys I hadn't come across the hepvo valve so this helps sort out dealing with the sinks and not losing what little space is available. I will probably use the Cunningham on the shower with a hepvo past it, just to keep it on the trailer.
Swirl-o-matic & Cunningham Toilet Parts graniteshore Sinks, Showers & Toilets 0 07-15-2011 07:50 PM
Has anybody repaired a Cunningham toilet? ddstech Sinks, Showers & Toilets 0 08-21-2010 11:19 PM
Cunningham Toilet lwebb Sinks, Showers & Toilets 0 10-28-2008 05:59 AM
P Trap Cup Chitown AirStreamers Plumbing - Systems & Fixtures 2 07-29-2003 02:34 PM
tub p-trap Paul Mayeux Sinks, Showers & Toilets 7 02-19-2003 11:24 AM
