Old 04-14-2010, 06:29 AM   #1
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
CPVC Piping
In the 1996-97 Excella 1000's was this the only year that CPVC was used and why? Trying to be cheap or some other reason.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-14-2010, 06:36 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I was not aware it was ever used from the factory.
Probably not the best material to use in a moving vehicle, However my 61 had been redone with CPVC so when I got it I continued with that theme, interspersed with the string reinforced flexible tubing in a couple spots and it has been trouble free for the 6 years i have used the trailer. The PO appeared to have heated the cpvc to work it around bends.
Cheap, readily available and easy to repair on the road.
I have a couple more trailers to re plumb and will probably invest in a PEX crimper and go that route but the CPVC has worked out better than I ever thought it would
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-14-2010, 07:17 AM   #3
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Yes, this straight from the factory. When it was put in there are no swivel joints-ie adapter screwed into water heater and then the run. Will be a real a$$ pain to change out water heater in a couple of years.
Bruce
CPVC Question kennethowens Fresh Water Systems 19 11-20-2009 05:45 AM
PVC piping Devoman Fresh Water Systems 8 09-30-2005 07:46 PM
CPVC vs. PEX? 3Ms75Argosy Fresh Water Systems 6 02-10-2005 07:37 PM
Water Pump Piping Navigator Water Heaters, Filters & Pumps 2 02-08-2004 10:16 AM
Hot water piping Pahaska 2002 - 2005 International 8 01-29-2003 07:19 AM
