Old 05-31-2016, 02:08 PM   #1
2011 27 FB International
Vancouver , British Columbia
Considering whole system water filteration
I'm considering adding a 3 canister + UV filter system and am wondering what people think...
Wife got a Berkey gravity filter, it takes a lot of space to use and store. I'd rather have a builtin system that is out of the way.
The carbon filter is rated at 4gpm (same as the pump), UV is rated at 5gpm. I'm not sure what the gpm is in the Airstream without filtration, so I'm not certain if this will be too low or not and whether I should add a 2 gallon tank.
I'm considering the closet for placement. This is above the pump and next to the city water inlet. Pump and inlet would both lead into the filters (and there would be a bypass of course). Because of the curvature of the wall in the closet, there is dead space at the back which I think would be enough for the system.
Example of what I'm looking at:
http://www.rvwaterfilterstore.com/WCUVSystems.htm
mixedpuppy is offline   Reply With Quote
Old 05-31-2016, 02:42 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Why go to all the trouble ? We use a camcorder rv water filter , it goes on your intake hose about $15, replace every year.......
Old 05-31-2016, 02:46 PM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
That should say camco rv filter ....
Old 05-31-2016, 03:06 PM   #4
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I have the camco filter, I think most of us that filter water start with that. It's cheap and better than nothing. It's rated to filter to 100 microns. I'll continue to use that filter to intially filter the shore supply, tank or city.
In addition I've decided to re-plumb both the water pump and shore supply through a 3M RV house filter (Model WV-B2) It will filter down to 0.2 microns and 99.99% of bacteria, cycsts, and other nasty stuff. I like that its compact and barely fits within the tiny utility area on my trailer. With a 7,500 gallon rating it should easily last a season.
Checking flow rates with a bucket and timer, I found the kitchen sink flows at 1.5 gallons per minute and the shower at 0.9 gallons per minute. I did install a low flow shower head. Both measured pre plumbing mods.
Frankly, I've never had problems with water quality, and we've camped all over the western US and British Columbia. However it only takes one instance. The system you are looking at is a pretty serious system.
kscherzi is offline   Reply With Quote
Old 06-01-2016, 06:04 PM   #5
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Your '3-M' filter sounds a lot like the portable "First Need" water purifier that Backpackers use in the wilderness. They advertise that it is the ONLY filter certified by your EPA as a 'water purifier'.
I had one when I was backpacking a number of trails in Canada and Vermont. It also filtered down to a nominal 0.2 microns or smaller, and one year made my trip up the Rideau Trail possible. It was a Hot July, and my water came from mostly swamps, turgid streams and ditches.
This filter made the day. I used it for over ten years, changing the filter occasionally.
MelGoddard is offline   Reply With Quote
Old 06-01-2016, 06:34 PM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Only my opinion of course and with all due respect, but frankly if you and your spouse are so concerned about water quality that you would consider this type of setup, then perhaps you should rethink going camping in the first place.
Bob Martel
WBCCI# 5766
Old 06-01-2016, 08:48 PM   #7
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
I would add, do you really need to filter water to the sinks, shower and toilet? If the water at a particular campground is so bad (this really is rare) just don't go back.
StreamDog is offline   Reply With Quote
Old 06-01-2016, 11:43 PM   #8
If you have to say with respect it is likely without respect. Considering it is followed by "but frankly", I see no respect in your comment.
Old 06-01-2016, 11:46 PM   #9
Because it makes it connect and forget regardless whether the water is via city hookup or fresh tank. I don't have to drag out equipment, I don't have to constantly fill a contertop filter.
Cities have outbreaks, I've been in places with boil orders. Well water is not always great. Yes, most of the time in most places in NA the water is fine. On occasion it is not.
Old 06-02-2016, 12:28 AM   #10
2007 22' International CCD
My only question is about how often you might have to replace filters on a system like this?
In my opinion, if you are concerned about water quality, it's certainly worth considering. Folks sensitive to water pollution should seriously consider this.
We tend to drink bottled water, and our dogs only get bottled water on the road. Trust me, a dog with an upset tummy is a real problem in the TV or AS. They seem to hold gallons....and since we travel with six, you can see the issue!
Note that if the system removes chlorine, using the water from the filter in your fresh tank may grow bacteria unless you chlorinate the tank a bit. If the filter only removes microbes and stuff, it won't be necessary.
Campground water with a lot of sediment might need a pre-filter to get the big chunks out.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 06-02-2016, 12:30 AM   #11
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I agree. Unless you're boondocking and getting your drinking water from surface water (lake, river, etc.) you won't need that level of treatment. Or unless you're traveling to Mexico where water quality standards are much lower than they are in the US and Canada.
Any campground water supply will either come from municipal sources (water treatment plants) or from a water well approved by whatever State agency licenses wells (in Louisiana it's the Department of Health and Hospitals). Water quality can vary based on the number of people who use the water, and whether those people are permanent residents or transients, because testing requirements vary based on those criteria. And potable water (safe to drink) may not always be palatable (pleasant to drink).
The granular activated carbon (GAC) filters made by Camco and others will turn potable water into palatable water. They will not turn non-potable water into potable water without additional treatment. But as I noted already, you're unlikely to be getting your drinking water from a non-potable source anywhere in the US or Canada unless you're getting it direct from Mother Nature or at a dump station hose.
The system cited by the OP is suitable for treating "raw" well water, or rainwater collected in a cistern, that has not been treated at all prior to entering this filter. It's overkill for follow-on treatment of water that has already been treated once at the source.
Side note, potable water meets the requirements of the EPA's Primary Safe Drinking Water standards with regard to contaminants that may cause short-term or long-term health hazards. Palatable water also meets this requirement, but goes one step farther, to meet the EPA's Secondary Drinking Water standards by addressing issues such as taste, color and odor.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-02-2016, 12:39 AM   #12
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, we use our fresh water tank for washing dishes, washing hands, taking showers, and flushing the toilet. For drinking and cooking we use bottled water. You can buy a ton of bottled water for the price of those filter systems. I have and use an inline water filter to protect my plumbing.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-02-2016, 12:41 AM   #13
The filter would be after the city inlet and pump outlet. Water pumped from the fresh tank would end up going through the filter system before anything else.
Old 06-02-2016, 01:13 AM   #14
Ok, then it should filter water from tank and city water. You might consider a connection to allow occasionally flushing the system from the output of the filter side, just so you can sanitize it. Perhaps a spare pump or something. Same issue about leaving some residual chlorine in the system for cleanliness.
For us, it's a Camco in line filter outside the AS and bottled water otherwise. Filter is replaced at least once a year, and fresh tank sanitized regularly. If the water system at a commercial campsite looks sketchy we don't use the water at all. Must admit to not having an issue yet...
Would also be cool to have a tank filler valve on the output of the filter so tank could be filled with filtered water. I'd use a check valve and vacuum breaker after the fill valve.
KE4GNK/AE
Wanting to replace the WHOLE bathroom... larrylisa Sinks, Showers & Toilets 24 04-01-2015 10:19 AM
'55 FC The Whole ball of wax NorCal Bambi Repairing/Replacing Floor &/or Frame 325 03-10-2014 08:29 AM
Whole-house surge suppressor? Foureagles Electrical - Systems, Generators, Batteries & Solar 9 03-03-2008 04:29 PM
Need the Whole Tail Light Unit for a 73 Argosy Trailer josephhh Lights - Interior & Exterior 3 09-03-2005 10:45 AM
Six whole months Pahaska Our Community 3 12-02-2002 08:44 AM
