Old 09-09-2015, 01:41 PM   #1
Clogged Shower Drain on MH
1999 Land Yacht MH 30'. Shower drain is a step-on to close, step-again and it is suppose to spring open. According to the AS manual it is called a "swivel strainer". Problem is that it appears to be gunned-up with very slow draining. Any ideas as to how to clean it out, short of disconnecting the p-trap underneath?
Mike
comprose is offline   Reply With Quote
Old 09-09-2015, 01:45 PM   #2
2007 22' International CCD
Remove stopper, then try one of the plastic hair clog removers from a big box store. It looks like a long plastic strip with teeth on the edge. Slip in it as far as you can, then gently pull it out with the hair and other crud stuck to it. I'd use gloves as it can be messy.
Old 09-09-2015, 02:07 PM   #3
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
The strainer should just unscrew. Try to unscrew it carefully by hand - more than likely hair and other gunk have collected around the pop-up mechanism which is causing it to malfunction.
Long time ago I worked in apartment maintenance and I don't know how many times I have had to do the same thing to repair the same complaint about that type of stopper. Good Luck!
Our Website: https://airstreamnerds.com/
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 09-09-2015, 02:08 PM   #4
Manassas , Virginia
BTW - if you do get it apart you can use WD40 or something like that to get the pop-up working smoothly again.
Old 09-18-2015, 03:05 PM   #5
Thank you all. It all worked a s. You suggested; learn something everyday.
Help Needed ASAP - Black Tank Clogged sigv Waste Systems, Tanks & Totes 12 09-03-2017 05:14 PM
Broken or clogged A/C drain line danjoe91 General Repair Forum 5 05-13-2013 09:01 PM
Black tank flush clogged??? crazylev Waste Systems, Tanks & Totes 6 07-25-2009 07:47 PM
Black water rinse clogged! Resorts Waste Systems, Tanks & Totes 5 02-15-2009 12:30 PM
Help! Yucky clogged shower drain Blu_Hwy_Lady Waste Systems, Tanks & Totes 25 05-10-2006 01:07 PM
