Old 03-28-2012, 05:41 PM   #1
rhutson's Avatar
1980 25' International
Lorton , Virginia
City water to Tank water transition?
Getting ready to take our 1980 international on its maiden voyage outside the driveway. I was checking out the water systems and after filling up my fresh water tank, and turning on the pump, I cannot get any water to comeout of the faucets. When I turn on the pump, it just runs and runs and I never get any water out of any faucet. I primed the system with city water, and the pump will not cut on when the swithch is on, but as soon as I open a faucet to releave some pressure and get some water, the pump starts right up, but I can get no more water after an inital trickle. I have read in another forum that this may be due to the fact that I may have a leak in the line from the fresh water tank that causes me to lose vacum. Are there any other valves that I should throw when changing from city to tank water? Guess I will have to stick to the city water for this trip, unless there is a simple solution that I am unaware of!!! Thanks for any ideas!
Rick
rhutson is offline   Reply With Quote
Old 03-28-2012, 05:57 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My trailer has a valve inline just before the pump which allows antifreeze to be pumped into the system. Since I live in a very warm climate, I have never used it. You might check to see if there is one on your system.
Richard
Old 03-28-2012, 06:30 PM   #3
rhutson's Avatar
Lorton , Virginia
Richard,
Thanks for that information. I will definitely check it out!
Rick
Old 03-28-2012, 08:48 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Try disconnecting the discharge line from the pump. Then turn on the pump for a short period of time. Water should squirt out. If so, put the line back on the pump, open a faucet and try it.
If you get no water out of the pump with the hose disconnect, check to make sure there is water at the intake of the pump.
Mid way through interior vinyl removal - how to remove remnants and cross-hatch? mikeandnora Upholstery, Blinds, Walls & Interior Finishes 24 07-12-2012 09:12 PM
Free Kindle book: How NOT to RV; The RVers Guide to RVing in the Absurd eubank Fun & Games 8 05-10-2012 06:22 AM
twisted safety chains - damage to chain holders Ramblinboy Hitches, Couplers & Balls 7 04-23-2012 04:12 PM
Who says dogs don't go to Heaven? :) Kittypuke On The Road... 49 03-28-2012 05:08 PM
Cheese to Wine vanster Airstream Lifestyle 6 03-28-2012 10:27 AM
