Old 06-07-2007, 11:41 PM   #1
utahredrock's Avatar
1962 22' Safari
1973 25' Tradewind
1968 30' Sovereign
Salt Lake City , Utah
Checking the System
This may already be out here, if so please direct me to the thread.
What are some simple procedures I can go through to see if the water system checks out? I am a little reluctant to try the water at all on my new 1968 trailer, but figure I better do it to find out what if any problems there are.
utahredrock is offline   Reply With Quote
Old 06-07-2007, 11:50 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
As you may know, there are 2 systems in your trailer.
A 12 volt pump operated system that pumps the water from your trailer's tank into your faucets/toilet/shower. This requires that you turn on the water pump switch, then try your faucets. It also requires a working battery.
There is also a system that uses water from a domestic supply such as your home water system. To access this, hook up a hose to the trailer at the rear bumper. turn the faucet on and check the trailer operation.
This may be info that you already know, if so I appologize. I don't know what your experience level is.
If you have more questions, ask away.
Dave
Fyrzowt is offline   Reply With Quote
Old 06-07-2007, 11:52 PM   #3
Fyrzowt's Avatar
2000 25' Safari
Images: 8
By the way, Welcome to the forums!
Old 06-09-2007, 10:21 PM   #4
1962 22' Safari
1973 25' Tradewind
1968 30' Sovereign
Thanks for the replies . . . guess I do already know those things . . . just reluctant to try things out in case there's a big problem! Shouldn't be such a wimp I suppose.
The trailer has cleaned up nice but still needs much work too. Would love to just rehab old Airstreams.
Old 06-10-2007, 07:01 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
When you check the water system, use a helper. Have the helper stand by the shutoff (spigot), and they can turn the water off immediately if you find a leak inside, minimizing any floods.
Old 06-10-2007, 07:04 AM   #6
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
If you have access to an air-compressor, you might try that route. I would just hook it up to the city water intake side and, have someone listen for any sounds of hiss..You might feel better doing the walk around inside yourself.
By doing it this way, you would prevent any water damages if you have a broken line or leak in the system. Just a thought..
ciao
53FC
btw, those air-compressor adapters can be had from any WALLY's store for around a buck or so..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 06-10-2007, 07:16 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Stop
Make sure that the crossover valve is OFF (closed) before you turn on that connect to the city water. That valve controls water into the tank if you want to fill it from the city connection. If thats the choice, then make sure that the outside fill cap is off, or loose, to prevent air pressure build up in the tank. The crossover valve should remain in the OFF position whenever not filling with city water.
electrical system 67 tradewind boardsander Electrical - Systems, Generators, Batteries & Solar 3 10-14-2002 04:32 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Flowmaster RV exhaust system rdm Airstream Motorhome Forums 2 07-09-2002 03:35 PM
Water filter system 53flyingcloud Our Community 2 07-05-2002 04:43 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
