Old 12-26-2013, 12:26 PM   #15
Maniacal Engineer
barts's Avatar
Menlo Park , California
I used the push-on fittings when I replumbed our Tradewind.. To allow closer connections and to save on fittings, under the kitchen sink I used a manifold made of 1/2" copper tubing fittings. This saved several fittings and made for a tidier installation.
I like the push on fittings because I often do things in stages to keep the trailer operational as much as possible. I will redo things slightly once more to add a hot water circulation pump. This will save water when boondocking, since we don't need to run the water to get it hot, and will help things from getting too cold in the winter.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 12-26-2013, 03:12 PM   #16
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Before you start, draw a detailed diagram of the old plumbing. It's a great resource when you put things back together few days later.
They say three things happen to us as we get older. We lose our memory, and I can't remember what the other two were.
Old 12-26-2013, 03:46 PM   #17
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
I think one of the others is called MEMORY MUSCLE, it's where you do the same thing over and over( and expect different results).
goshawks00 is offline   Reply With Quote
Old 12-26-2013, 05:39 PM   #18
bwoodtx's Avatar
1997 30' Excella
1981 28' Airstream 280
San Antonio , Texas
I thought that was INSANITY
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 12-26-2013, 06:13 PM   #19
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
It is not an either/or decision for the fittings. The crimp is cheap, fast, effective. But if it is in a tight place or if you might want to take it apart later you can use the push together fittings in some places.
Before I discovered PEX and crimp fittings I used the sharkbite fittings on PVC to redo my broken water entry fitting. Its been fine for 8 years and a trip to Alaska.
Old 12-26-2013, 06:49 PM   #20
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
maybe that was the third
Old 12-26-2013, 06:51 PM   #21
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Yes exactly... crimps are very cheap and easy.. push togethers are expensive but very practical in tight places.
Old 12-27-2013, 08:23 PM   #22
sleepybear74's Avatar
1973 Argosy 26
brooksville , Florida
so hubby is thinking sharkbite push on fittings for ease of use in small cramped places. we dont have to worry to much about that memory issue since we have an identical argosy 73' sittiing in the back yard, well that and i took a TON of pictures!
sleepybear74 is offline   Reply With Quote
Old 12-27-2013, 08:49 PM   #23
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
I redid the plumbing in our 71 Sovereign... wasn't too bad... used all crimp rings...was tons cheaper than push on connectors...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Can pex be attached to plumbing in 1988 AS? nm1oqrz Fresh Water Systems 5 09-25-2011 03:36 PM
PEX crimp vs. press on Sharkbite experiences idroba Fresh Water Systems 17 08-31-2011 09:15 AM
copper plumbing in 1965 Trade wind Dr Dan Fresh Water Systems 5 07-14-2011 07:41 PM
PEX Replacement CAN NOT BE DONE...'75 Tradewind... onemanclan Plumbing - Systems & Fixtures 40 04-16-2011 08:50 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
