Old 06-10-2015, 04:08 PM   #15
2007 22' International CCD
Typically mud dauber wasps or the like...
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 06-10-2015, 04:18 PM   #16
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I think the OP has it figured out. He has been opening the wrong drain valve.
MICHAEL
Old 06-11-2015, 10:30 AM   #17
2010 23' International
Calgary , Alberta
Well last night I opened the white spigot valve (w/o problems) and water started to drain out but very slowly. Previously I had opened the low point drain and water would shoot out as if under pressure (maybe just discharge head). Thanks again everyone.
Hingafer is offline   Reply With Quote
Old 06-11-2015, 06:16 PM   #18
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Mine drains slowly also. Like several hours. It is a small diameter valve. Your low point drain valve may have had some water pressure behind it from the water heater or accumulator somewhere.
David
drain valve on fresh water tank: '79 Argosy 6.0 campman All Argosy Trailers 7 01-26-2009 06:59 PM
Is there a drain for my Fresh water Tank!! Mrcrowley Fresh Water Systems 1 12-02-2008 04:44 AM
Fresh Water Tank Drain NEW94 Fresh Water Systems 5 11-04-2007 08:58 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
Really need a drain on the fresh water holding tank?? SmokelessJoe Fresh Water Systems 16 06-17-2007 07:50 AM
