Old 01-23-2016, 05:38 AM   #1
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Can you calibrate a SeeLevel Monitor?
2016 25' FC - We have noticed that the percentage full shown on the monitor for the grey water tank appears to be inaccurate. It jumps from something like 25% to 50-55% after maybe 2-3 gallons are added, and then jumps to 80% with just a little more added. It's a 39 gallon tank, so every 25% should be just shy of 10 gallons. On our recent trip we let it to go 100% and kept using it for a little while longer and didn't see any backup issues.
I don't see how it could be dirty or anything like that since it's new, but I am wondering if there is any way to recalibrate it, or if anyone has other ideas. The black water tank monitor seems to be more accurate from what I can tell.
Thanks.
SeaLevel is offline   Reply With Quote
Old 01-23-2016, 05:47 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
After retrofitting the SeeLevel 714 system to our 2014 Classic in 2015, it has taken awhile for the system to learn our tanks.
Putting a measured 3 gallons in the black (39 gallon) or gray (37 gallon) tanks shows we have 5% and then 10% in the tanks.
Our installer stuck the device to the lower part of the fresh water tank to make it more accurate as the water level decreased and put the black and grey high near the top of the tank to be more accurate as the tanks get close to capacity. When our fresh water tank shows full, we can put another five gallons or so in the tank.
We have only had one two day trip with the 23D, so it has yet to learn about the tanks.
switz is offline   Reply With Quote
Old 01-23-2016, 05:53 AM   #3
dznf0g's Avatar
2007 30' Classic
Oswego , Illinois
In reply to both posts. The quality of the reading is dependent upon the installation positioning.
-Rich-
Old 01-23-2016, 07:16 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
New Lucy's tank monitor system is better than Old Lucy's, but has its quirks. Now that we have over 200 nights in New Lucy, we have noticed several anomalies. When we fill her fresh water tank, the monitor reaches an indicated 100% about three or four minutes prior to overflow. When the gray tank level shows 100%, we can squeeze in another brief shower without backing up into the shower pan.
Although not perfect, the new monitor system seems to be more reliable that its predecessor.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 01-23-2016, 07:17 AM   #5
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I would check all the tanks for accuracy.
Purchase an inline water meter that connects to a hose.
Go to a full hookup RV park for a weekend trip. Drain all the tanks.
Fill up the fresh water tank at 10 gal intervals and see what the gauge states.
Use the black tank flush to fill up your black tank at 10 gallon intervals and check the panel.
Take the hose into the shower and fill the gray at 10 gal intervals and check the monitor.
Take your Airstream into your dealership for warranty.
To bad SeeLevel doesn't have a way or user calibration to tweek settings.
Kelvin
2008 Classic 25fb "Silver Mistress"
2015 Ram 2500 6.7L Cummins. Crew Cab, 4x4, Silver
KJRitchie is offline   Reply With Quote
Old 01-23-2016, 07:49 AM   #6
dznf0g's Avatar
2007 30' Classic
Oswego , Illinois
I did my own install and purposefully installed the sensors (12", trimmed to fit tank height) so that:
Fresh tank - shows full when it is full and empty with 6 gallons left. That allows the finish of a shower with no surprise.
Gray - show empty when truly empty and full when there is room for about 5 gallons more, to prevent those unexpected overflows.
Black - same as gray.
It has been flawless thus far.
This level of accuracy of install is less than likely with a factory install, as it takes some time and effort to get it the way you want it.
-Rich-
Old 01-26-2016, 08:20 PM   #7
2020 Classic 33
Box Elder , South Dakota
Only adjustment/calibration is to move the sender tapes up and down. My Fresh Water has always been dead accurate based on my refill with an inline water meter just so I know what I use on a trip. And I rarely do hookups so 99% pull from the onboard tanks. Grey was repositioned at the factory last fall and was setup to be more accurate as the tank got fuller, less accurate when closer to empty. Shows full with about 7 gals left. For some reason not as accurate as the fresh water.
Black I didn't have them check nor have I tried to simply fill it with water. Maybe sometime in the future when I am at a CG with full hookups and spare time I'll check it.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 01-26-2016, 09:20 PM   #8
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Mine are very linear. It could that your senders are delaminating from the tanks. If so things will only get worse. Take it in for a warrenty review.
kscherzi is offline   Reply With Quote
Seelevel 700 series monitor from Garnet Robo104 Electrical - Systems, Generators, Batteries & Solar 3 04-28-2015 06:35 PM
Is it ever necessary to calibrate the new SeaLevel Tank Monitoring System? Hibby Waste Systems, Tanks & Totes 11 10-23-2014 05:28 AM
How do you calibrate the auto leveler? wvabeer Land Yacht/Legacy Motorhomes 14 05-14-2013 07:36 PM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
Calibrate Monitor Panel Where? ts8501 Plumbing - Systems & Fixtures 2 07-11-2008 08:42 AM
