Old 05-03-2006, 09:38 AM   #1
Alden Miller's Avatar
1993 34' Excella
, Maryland
Can it really be this easy?
I had a problem with my toilet leaking. The carpet just in front of the toilet would get wet after a few uses.
I searched this forum and found useful information about my Thetford toilet and repairing it.
I was all prepared to remove the toilet and replace the gaskets.
I went to remove the toilet last night and found that the nut at the front base of the toilet was loose. I tightened it down and poured a bucket of water in the toilet.
No leaks! I flushed repeatedly and still no leaks!
I am having a hard time believing that the fix could be this easy!
Thanks for posting the good information for me to search!
-Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
Alden Miller is offline   Reply With Quote
Old 05-03-2006, 09:40 AM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Man, talk abt luck~!!
Sometimes, it's just that simple...
Good for you and, for showing us all "how to step back"....
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 05-03-2006, 09:46 AM   #3
Images: 59
Alden,
You inspire the rest of us.
I'm still looking for the one job that turns out to be less complex and easier than planned.
Old 05-03-2006, 09:49 AM   #4
Elgin , Texas
Images: 164
Originally Posted by markdoane
Alden,
Amen to that! Sheesh!
bake315 is offline   Reply With Quote
Old 05-03-2006, 06:04 PM   #5
the ponz's Avatar
Detroit , Michigan
loose nuts
During the first longer than three day outing in our airstream, I came home to find the bathroom floor very wet. I wasn't sure if the hot water heater was leaking or if the toilet was the leaking. I removed the hot water heater and pressure tested the tank. Upon further investigation, I discovered the exact same thing that you had; that being loose bolts on the toilet. The rear bolt was not even hand tight. It appears that in order to tighten the rear bolt, one needs the arm size of a ten year old which is jointed in four places. A rachet end wrench made the job a bit easier.
As far as removing the hot water heater, I was consoled that during reinstallation, I upgraded the gas line, installed a bypass to assist when winterizing, and installed braided flex lines for the hot and cold lines going to and from the tank.
I now check the toilet bolts for tightness when I get the trailer ready in the spring.
86' 31' Sovereign
the ponz is offline   Reply With Quote
Old 05-03-2006, 06:43 PM   #6
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Alden,
Talk about luck! The water valve on my brand new toilet (can't remember the name at the moment....really good german beer) was cracked and leaked all over my brand new marmoleum. This of course did get fixed by the resto shop, and all is well with the universe again.
442.....What a great car!!!!!
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 05-03-2006, 09:34 PM   #7
1993 34' Excella
, Maryland
Still Dry
I checked this evening when I got home. The water that was in the bowl for 24 hours had pretty much drained into the black water tank. Nothing on the floor!!!!!!
-Alden
Old 05-04-2006, 07:26 AM   #8
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Alden ~
You must be living part of your life right. Congrats. Here's to all of us finding one job/repair that is so simple. Cheers.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
7.4l tune-up ALANSD Mechanics Corner - Engines, Transmission & More... 84 05-23-2010 12:51 PM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Best battery charger for the money? Andy R Electrical - Systems, Generators, Batteries & Solar 27 10-01-2007 07:46 PM
deadbolt with inside twist style lock CindyH Doors & Locks 4 10-16-2002 08:58 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
