Join Airstream Forums Today
Old 08-20-2011, 09:20 AM   #1
brattwurzt's Avatar
1968 30' Sovereign
Baltimore , Maryland
Camco Camper Drain Trap?
Anyone have any experience with this little "trap"? It's made by Camco.
It only has a 3/4" barbed fitting as the "out" feed. I was hoping to use it as a shower drain on a shower in my 68 sovereign. My challenge is that I'm 6' 5" tall, so I need as much headroom as possible, and my grey tank is literally right under my shower pan. I have room for a regular trap, but then I would have to raise the pan by at least 1 1/2" to accommodate the pipe thickness. If I could use this trap, I would not have to raise the pan at all. I could simply route the 3/4" flex pipe to a 3/4" fitting on top of the tank.
My concerns are as follows:
1: does the 3/4" tubing limit the draining ability?
2: does this trap hold up over time?
dreamin' of streamin'
brattwurzt is offline   Reply With Quote
Old 08-20-2011, 11:17 AM   #2
brattwurzt's Avatar
1968 30' Sovereign
I have another question for the drainage experts. I have seen drains going into the side wall of the grey tank. I thought you has to enter on the top of the tank. Is entering on the side wall acceptable?
How should I run power to my camper. Avion C-11 Electrical - Systems, Generators, Batteries & Solar 8 08-03-2011 04:07 PM
Fresh Water Drain Valve Wrench withidl Fresh Water Systems 6 05-13-2011 07:31 PM
A/C drain tube is kinked Janie Q Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-22-2011 07:51 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
