09-30-2016, 03:35 PM
2016 27' International
Montreal
, Quebec
Calling all engineers
It seems that everyone can agree that the monitor for gey water is not really reliable. Do you think that some kind of water meter installed just before the grey water enter the holding tank would be more reliable? Of course that would not work for black water but I could see it working to monitor the amount of water leaving the fresh water tank. I would think that if it is not done right now there might be good reasons but I am curious to find out if you think this could be a valid option.
09-30-2016, 04:23 PM
1981 31' Excella II
New Market
, Alabama
My tank gauges on my 81 Excella II still work fine. They are resistance based. Usually the black water tank is the most problematic since stuff gets stuck to the sensors. Flow meters are not that easy to deal with and you need some sort of data acquisition system to monitor it and keep track of the total flow. If you can see the side of the tank you can use some clear hose attached to the top and bottom of the tank to show the level.
Perry
09-30-2016, 05:09 PM
2005 30' Classic
Burlington
, Ontario
Well, this ex-engineer wouldn't bother! I think it would be cost prohibitive anyway.
One fairly simple way that is use to measure liquid level in tanks consists of a long tube inside to the bottom coupled with a hand pump to pump air into the tube to force the liquid out. There is a pressure gauge on the air line and the pressure required to force the liquid out will be proportional to the depth of liquid and the pressure gauge can be calibrated in inches of liquid or gallons of liquid accordingly.
................ But I still wouldn't bother!
I gave up on the monitors on our trailer years ago and have never really missed them!
Black tank - look in the toilet
Grey tank - look in the shower pan
Fresh water - do your best to conserve water and put more when you have to!
We don't often camp without full hookups, but I have developed a few tricks to help deal with tank capacities as best we can when we have to do so!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
09-30-2016, 05:17 PM
2015 30' Classic
Pleasanton
The SeeLevel II monitor is quite ingenious in that it can sense liquid levels from the exterior of the container without any moving parts. Sure, the sensor can be incorrectly placed or poorly attached and the inside wall of the container must also be kept reasonable clean for it to work correctly. No system is without weaknesses. However, I'm quite impressed with this technology and expect it to be reliable for years to come.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
09-30-2016, 05:52 PM
2021 25' Globetrotter
Jamestown
, Rhode Island
I threw away our factory installed system a couple of years ago.
Here is a link to the thread I started at the time.
The new system has worked perfectly from the moment it was installed...
Bruce
http://www.airforums.com/forums/f163...se-102968.html
Loving our 2021 Globetrotter 25 and our 2022 Ford F-150 King Ranch 5.0!!! Plenty of payload, not even close to axel limits and it drives and rows beautifully…
09-30-2016, 06:34 PM
Oswego
My SeeLevel works perfectly as well.
-Rich-
09-30-2016, 07:20 PM
2014 27' FB Eddie Bauer
Mobile
, Alabama
No complaints on the SeaLevel system
09-30-2016, 07:25 PM
Montreal
, Quebec
Happy to see that for most of you the seelevel monitor seems to be adequate . In the very short time I used it mine did not seem to be acurate at all.
09-30-2016, 07:31 PM
2019 25' Flying Cloud
Woodland
You can have it cheap, accurate, or reliable: choose two.
Guess which two Airstream chose.
09-30-2016, 07:40 PM
2007 22' International CCD
Corona
Meh. They only picked one....
09-30-2016, 07:42 PM
Oswego
Who installed? It's all about proper installation.
-Rich-
09-30-2016, 07:49 PM
1969 29' Ambassador
brooksville
See level works well, just keep it away from metal. And you tanks can't be made out of metal.
http://www.adventurerv.net/see-level...source=Froogle
09-30-2016, 08:03 PM
Montreal
, Quebec
It is the model that was installed at the factory on my 2016 27fb International.
09-30-2016, 08:32 PM
New Borockton
, Alabama
I wasn't aware there was agreement on the grey water tank not being accurate. I'm also surprised to hear your SeeLevel is not accurate and I too agree it's likely in the installation. I wouldn't give up on it.
To your question or proposal for engineers, its not a bad idea but the end would have to justify the means. Also, many RVers don't use the fresh water tank a lot or certainly not exclusively so monitoring the exit level of the fresh water tank (if I understand you correct) would only work for true boondockers. Again, not a bad idea and I'm sure you have some people thinking.
We toyed with the Catcon system and sensor a few years ago when Airstream was using them and they were just okay at best but in the end, the SeeLevel is a better system in my opinion. That said, we have not got one single call back on them that I can remember in 8 years. Not one! They must be doing something right and I'm glad to see them standard equipment on more and more OEMs. They're pretty darn good, easy to install and accurate.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
09-30-2016, 09:15 PM
1972 31' Sovereign
Silverton
, Oregon
No it won't. Water meters require flow.
"Daddy when's the trailer going to be finished?"
It's done. I mean mostly. It works anyway.
09-30-2016, 09:31 PM
Superior
Brian.
This retired engineer has the same philosophy. Keep it simple. We're camping, not on a space mission.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
09-30-2016, 09:57 PM
1972 25' Tradewind
North Vancouver
, British Columbia
Install a dipstick...
North Vancouver, BC
09-30-2016, 09:59 PM
New Borockton
, Alabama
Where are you going to connect it and get the readout?
888-828-1893
Bestconverter.com
10-01-2016, 01:38 PM
Montreal
, Quebec
So it seems I had an impractical solution to a problem that does not exist
That's what I like about this forum you can run your idea by a bunch of people with experience and knowledge and you can be sure to receive an honest opinion.
Thaks everyone
