Old 05-26-2015, 04:06 PM   #1
Clyde , North Carolina
Broken have missing valve
Just picked up this 1989 29' Airstream. Can't fill fresh water tank as is just drains from this white plastic fitting between wheels. Looks like part of the fittingClick image for larger version
Name:	ImageUploadedByAirstream Forums1432677961.371692.jpg
ID:	239313Click image for larger version
Name:	ImageUploadedByAirstream Forums1432677980.473881.jpg
ID:	239314 is broken away. What is this fitting called as I would like to order a new one. Thanks!
Wycolo is offline   Reply With Quote
Old 05-26-2015, 05:55 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Any hardware store should have one! It's a flush mount 1/4" barbed petcock. Anything will be better than the one fitted as oem!
1988 Excella Door Latch broken/piece missing K9GVF Doors & Locks 3 07-02-2012 07:31 AM
Need to replace my black water valve/ broken bolt 71 Overlander u2bewell Waste Systems, Tanks & Totes 1 07-26-2010 10:35 PM
Black water dump valve push pull rod missing 79excella500 Waste Systems, Tanks & Totes 2 08-26-2009 08:44 PM
4th broken water tank drain valve gklott Fresh Water Systems 17 02-12-2007 01:50 PM
Broken dump valve Ed Starman Waste Systems, Tanks & Totes 1 05-24-2005 09:02 AM
