Old 04-10-2003, 08:29 PM   #1
73ANDY's Avatar
Images: 18
Bladder Tank
Hey, has anyone ever added a small Bladder tank to their water supply system? It seems like it would help reduce the click click click as the system is getting up to pressure. Or will this defeat the whole "on demand" pressure switch senario????
Any ideas on this?
Rick
73 Overlander
1997 GMC Suburban
73ANDY is offline   Reply With Quote
Old 04-10-2003, 08:40 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
got one!
73andy,
my trailer has one, original equipment.
works well!
john
Old 04-10-2003, 08:53 PM   #3
73ANDY's Avatar
Images: 18
Bladder Tank
Is your pump a PAR pump?
What size of Bladder tank is installed?
Rick
73 Overlander
1997 GMC Suburban
Old 04-10-2003, 09:43 PM   #4
pap
Question
Ok guys i'll set the table, what exactly is a bladder tank?
pap is offline   Reply With Quote
Old 04-10-2003, 10:04 PM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Pap,
It's also referred to as an accumulator, but it's main purpose is to dampen water pressure shock to avoind pipe rattle, and to supply instant pressure when you turn the water on. It makes it so the pump runs a bit less often as it delivers water the moment you turn on the faucet.
Uwe
www.area63productions.com
Old 04-11-2003, 08:58 PM   #6
87MH's Avatar
1978 31' Sovereign
Images: 292
Size of bladder tank
We had a houseboat that had a pretty typical RV type of water system.
Pipe hammer, while not a problem per se, was evident. Also the water flow varied quite a bit when the pump cycled on and off.
Note that neither of the above was a really serious problem. (In my opinion.)
Installed a 12" diameter SS globe mounted with the inlet down, system was running at about 30 lbs, so we figured that the globe was running about 1/2 full.
The volume tank helped with both the pipe hammer and evening out the water flow, but cost effective? I think not.
I would have to say, though, that if a "micro-leak" was causing the pump to cycle during the night and disrupt sleep, that a significant expense might be warranted, but you could always turn the pump switch in the off position during the night.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 04-12-2003, 01:46 PM   #7
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
i have the bladder system and my wife loves it . constant water pressure when in the shower makes a big difference. if you have to justify the cost you wont. just preference. lol
al
wb13798 is offline   Reply With Quote
Old 04-15-2003, 06:46 PM   #8
73ANDY's Avatar
Images: 18
Bladder Tank Problem!?
Well, I installed a bladder tank(accumulator tank) over the weekend.
The pump cycled perfectly the first time and filled the tank and the lines up and shut off, however the next time it cycled, after I turned on the faucets and let them run for a while, it shut off, but then about every 20-30 seconds it acted like it was going to cycle again. I had lowered the air pressure in the air side of the bladder tank down to about 12 psi(because the pump cycles on at about 18 psi(+/- 4 psi)) so I don't think that would be the problem. I have been gone for the last few days and I haven't checked it again since that second cycle. Maybe it will run just right the next time I try it!?
I like the concept and I hope I can work out the "bugs".
Has anyone else had any similar cycle problems with theirs?
Rick
73 Overlander
1997 GMC Suburban
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
Replacing black and gray tank level indicators nickcrowhurst Waste Systems, Tanks & Totes 4 12-30-2003 08:42 AM
poor-man's grey tank Chuck Waste Systems, Tanks & Totes 9 09-05-2003 10:59 AM
'52 blackwater tank Cruiser Waste Systems, Tanks & Totes 1 09-01-2003 08:28 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 07:40 AM
