09-24-2018, 08:54 AM
2017 30' International
longview
Blackwater tank flush leak
On a recent trip to Yellowstone, upon leaving and at the dump station , I hooked up to my blackwater tank flush fitting and when I applied water had a major leak coming from under the shower onto the floor of the trailer. Anyone had this problem, tried removing the screws from the exterior fitting and it will only pull out about 1/2 inch , no slack available. I have a 2010 Flying Cloud 27 ft.
09-24-2018, 12:37 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
Inside the trailer in close proximity to the inlet is a vacuum breaker type backflow devise They can and do fail. Sometimes they can stick from spiders nesting inside causing them to leak
09-24-2018, 12:41 PM
1991 25' Excella
Santa Ynez
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
09-24-2018, 12:49 PM
2015 19' International
Boise
, Idaho
Mine just failed. Noticed a small seeping infrequent leak in a wheel well seam in front of the left tire. I looked around and didn’t notice anything obvious. Airstream service found it and replaced.
09-24-2018, 01:01 PM
NORTH MYRTLE BEACH
, South Carolina
Mine did the same thing first time I used it, I have interstate. Took it to AS in Jackson and something plastic was cracked and they replaced it. On mine, he had to get under fridge through grate to get to source. I went there because I already had appointment for other issues.
09-24-2018, 01:46 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
If it’s a 27FB, the access to the problem should be in the back-bottom of the closet as I recall. There is a step looking piece held by 4 screws.
09-24-2018, 02:19 PM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
I have had several fail. When I get a chance I'm just going to cut it out.
@living.somewhere.yonder | Instagram
09-25-2018, 07:53 AM
longview
Thanks for the help, I'll dive in this weekend and check it out
09-25-2018, 10:56 AM
2007 25' Safari FB SE
North/East
, New Jersey
rickmc1219..... I had the same problem with my 2007 25' FB Safari. The valve on mine is located behind a panel in the closet. Attached are some pictures.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
09-25-2018, 11:17 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Sometimes the black flush water pressure can blow up around the foam rubber toilet to flange seal. Most seals last about 10 years, so if you haven't replaced that I would do so ASAP.
guskmg
