Old 01-23-2015, 10:15 PM   #1
2007 19' Bambi
Studio City , California
Blackwater tank filling when not being used
I just got a 2007 19ft Bambi. Dream come true.
But i seem to be having a problem it is parked in back yard at moment no one is using toilet. I dumped out the blackwater tank the other day and now it say's it's half full. (event with no usage)
also i noticed that the fresh water tank seems to be going down. is there some way that the fresh water could be leaking into the blackwater tank.
thanks for any help
richard
recharge is offline   Reply With Quote
Old 01-23-2015, 10:33 PM   #2
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Hi Richard and welcome to the forums!
If you are going by the Micropulse tank monitor, they can be notoriously innacurate. I would start by dumping the black tank again to see if it actually is half full. If it is, water must be leaking into it at the toilet as that or the external sewer flush are the only ways to add water to it. If it doesn't have water in it, it must be your Micropulse. Did you notice if your pump was running? Good luck!
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 01-23-2015, 10:50 PM   #3
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Yes, our Micropulse monitor no longer correctly monitors the black and gray tank, only the fresh water tank.
Additionally, make sure your water pump is turned off unless you need it to be on! (Meaning, it should be off when you are just storing your trailer or while it is being towed!)
SilverGate is offline   Reply With Quote
Old 01-24-2015, 05:41 AM   #4
Gainesville , Florida
Bathroom sink may be plumbed into black tank. Not that unusual. Anyone using the bathroom sink? Jim
avionstream is online now   Reply With Quote
Old 01-24-2015, 12:37 PM   #5
Dallas Center , Iowa
If the water pump is cycling off and on when not using the plumbing then you have a leak of some sort. This will take some basic trouble shooting to identify where it is. It would be unusual for the black tank to be receiving any water from a source other than the toilet however the gray and black tanks come together in the dump connection on the outside of the trailer. There is a check vale on both the black and gray tanks as you know so it seems unlikely that gray is loading black but something to look at. The following link will provide the pluming parts and some of the layout of such. Manuals, Airstream Travel Trailers, Touring Coaches | Airstream
Refer to this manual and you will see exactly how the 2 tanks dump into a common out-flow pipe.
Earthcreeper is offline   Reply With Quote
Old 01-24-2015, 12:53 PM   #6
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Richard, your new to you, but old otherwise, trailer could have a variety of issues.
The previous owner could have done some plumbing and screwed up things. There could be a cross connection somewhere or a one way valve failure.
All of the possibilities above could be true. Check out the easiest ones first—is the toilet running all the time, is the bathroom sink leaking (some bathroom drains are connected to the black tank and some are not—I'm not sure which are and which aren't and it may have been done on some trailers of the same model and some not)?
Is the city water connection is use and the trailer has a constant supply of water? Is there water in the fresh water tank and is the pump on?
It is a process of elimination until you find the problem. Only do one thing at a time so you can identify the issue.
If there is no water in the fresh water tank and the trailer is not connected to city water, you have a magic trailer that is creating water and that is great considering California's persistent drought.
Gene
Old 01-24-2015, 01:00 PM   #7
PecanMan5's Avatar
2015 25' Flying Cloud
Hahira , Georgia
Is it locked up at night?
From my Pecan Tree
PecanMan5 is offline   Reply With Quote
Old 01-24-2015, 01:03 PM   #8
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Slow leak at toilet seal?
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 01-24-2015, 01:25 PM   #9
Gene's Avatar
That could mean either of 2 seals and both would have to leak. There's one in the supply line behind the toilet. If not cleared out in winter (we don't know where this trailer came from), that one can freeze and leak, but it would probably leak behind the toilet and could provide a fountain (don't ask how I know) under pressure.
But if it failed without leaking at the rear of the toilet and water was coming into the bowl continually, eventually the bowl would fill unless the seal at the valve at the bottom of the bowl was also leaking.
It is unlikely two things break at once. And one bowl full of water is not going to fill the black tank half full.
I suppose someone could have a residential toilet with a constant supply of water and that could leak (a bad idea because you would have to fill the trap underneath with antifreeze and someone might not remember to do that or it would be too diluted). That would be something a previous owner would have done.
And the Micropulse system was used back in '07 and the technical word for that system cannot be printed here. Ours never has worked well and some of it has completely failed. Over time we got to estimate pretty well how much water was in each tank, but that takes experience with it.
Gene
Old 01-24-2015, 02:21 PM   #10
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
I'm guessing space aliens... They do crap like that. If not space aliens, maybe a bad sensor reading on the black water tank, but seriously, how often does that happen?
-Red, sticking with the alien theory...
I would like to apologize for the above smarty pants response, but everybody else pretty much covered everything. Y'all got to leave me something...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 01-24-2015, 02:52 PM   #11
Turn the valve off fir the toilet and push the flush lever and hold it down at the same time as runninG water in the bathroom sink. You should here water running into the black rank if the sink is connected to it. Hope this helps. Jim
Old 01-24-2015, 04:47 PM   #12
2003 39' Land Yacht XL 330 hp w/2slides
Cincinnati , Ohio
Black Tank Full
Richard,
A good friend and RV expert turned me into PURE POWER to clean sensors in black tank. We own a AS Land Yacht motor coach. I got the same readings too. Empty but showing 1/2 full. Follow directions. Helps if you can move the AS around to agitate solution. I also used a BT sprayer after emptying.
Good Luck #4983
Happy Trails
rrstory is offline   Reply With Quote
Old 01-25-2015, 04:57 PM   #13
2007 19' Bambi
I just emptied the tank and it only had a gallon or two in it. So I guess it is the sensor.
I'll try the PURE POWER and see if i can get them to read proper.
thank you for all the replys
richard
PS the sensor now says empty. so i'm guessing the empty sensor is good then the ones between empty and 5/8 full are failing.
Old 01-26-2015, 06:31 AM   #14
StreaminGuy's Avatar
1967 17' Caravel
Cumming , Georgia
richard
Is it parked outdoors? Has it been confirmed that there is actually water in the tank ...or just indicated on the gauge. Is the cap missing cap from plumbing vent on roof? Rain water can come in there.
Thanks, G
StreaminGuy is offline   Reply With Quote
water pump not filling lines jeffdix General Repair Forum 5 08-01-2014 09:19 AM
Fresh water being used while using full hookup xo1rider Fresh Water Systems 6 01-18-2013 03:07 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 10:19 PM
Problem Filling Fresh Water Tank DaveJ Fresh Water Systems 8 10-14-2003 06:36 PM
Filling fresh water tank- overflow normal? John Fresh Water Systems 20 02-23-2003 01:43 PM
