Old 04-07-2014, 08:21 AM   #1
1989 29' Excella
Cumming , Georgia
Black Water Valve issue
Hi Guys,
So I just bought a vintage Excella, 1989.
Took her out on her first camping trip and when leaving and finishing up the dumping procedure I was not able to close the clip on the black water valve.
I had a conversation with the guy I bought it from. He said that I might try,
1. Putting a gallon of Hydrochloric acid from my local Home Depot in the black water tank.
2. Filling the tank with water the rest of the way.
3. Open a close the valve several times over and over.
4. Leave the valve open for a week half way.
5. Again open and close the valve several times, repeat.
6. Dump the tank.
I respect the guys advice immensely. That being said, I am putting acid in my black water tank. But I have to imagine that there are other materials in the tank that arenít plastic. Maybe rubber and or metal for level detection. I donít know.
He said that he felt confident that eventually it would come unstuck and the valve will close correctly.
So, Iím posing the question(s) here.
Is this a tried and true method to, ĎUn-stickí, vintage valves?
And if it does work is this something that I should work into my winterizing and or de-winterizing process?
Iím also considering just having the valves replaced. Iíve gotten prices from both AS and an AS dealer. Although pricey itís not so cost prohibitive if it eliminates this issue.
Dave
davcarv is offline   Reply With Quote
Old 04-07-2014, 08:37 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I have had the same issue with my 91 for several years. I think there is some material, most likely compressed paper, in the seat of the valve. To date it has only resulted in a small amount of balck water leaking into the area downstream of the valve. This means I open the cap with caution.
I would look at a replacement valve to be sure there is not any rubber involved in the seat of the valve before I would use acid. If the valve is plastic on plastic tat may be a course of action. If you do take that course you will have to just crack the valve as the tank is drained of the acid solution to be sure the blockage is subject to the acid for as long a period as possible.
Lot me know it it works.
2004 Excursion 4x4
Old 04-07-2014, 08:41 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
There are two reasons why a valve will not close all the way. The most common is something is stuck in the area where the valve blade seats. This would most likely be a piece of paper. The other possibility is that the seal is shot on the valve preventing it from seating correctly.
If you can get to the valve, you can take it apart and replace the seal. Rebuild kits are not very expensive.
Pouring acid into the tank sounds dangerous to me...
Richard
Old 04-07-2014, 08:51 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
6. Dump the tank.
I can't help feeling that this is a Bad Ideaô. Doing it as the guy said, by adding acid first, then diluting, you've got full-strength acid in the tank for however long it takes to get the water added. That can't be good for any metal parts, and probably not for most of the ABS plastic or rubber parts, either. Two different chemical resistance guides I consulted showed that ABS has only limited resistance to hydrchloric acid in concentrations above 10%. Another guide for rubber compounds indicates that nitrile rubber has poor resistance to hydrochloric acide; natural rubber has limited resistance, and butyl rubber has good resistanceó if the acid is cold! But I don't know if the rubber in your waste system is butyle rubber or some other type. And if the acid is hot, all bets are off; it will attack all rubber compounds equally.
If you MUST try this, dilute the acid with COLD water first, THEN pour it in. But by far it would be better to choose a different solvent.
Old-fashioned glycerine (available in the first aid equipment aisle of your supermarket) makes a decent lubricant and is actually good for rubber. I haven't tried using it for unsticking a waste tank valve, though.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-07-2014, 08:55 AM   #5
dznf0g's Avatar
Oswego , Illinois
What about the new Rid-X product for RVs? It has enzymes which will eat the paper. I would store it with that valve open and a good tight cap. When you open...stand back.
-Rich-
Old 04-07-2014, 09:53 AM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
No one has yet suggested a good backflush. I got a flush-king valve a few years ago and find it works nicely. Fits on the discharge with a gate valve. Upstream from the gate is a hose fitting. With the FK gate closed and the trailer black valve open you can backflush and put a large volume of water into the black tank quickly. I use it a couple of times a year and always when planning to store it for awhile. There might be other flush options but I feel that this one works well. Good luck with this.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-07-2014, 11:00 AM   #7
1989 29' Excella
Cumming , Georgia
thanks guys, ... For clarity, ... the valve isn't stuck in the traditional sense you may think.
The plunger pulls open completely and depresses inward seemingly completely.
However, I cannot secure the metal clips because they seem to need for the plunger to be depressed a bit further giving me the impression that the gate has not closed completely. I think it's because there is some sediment or TP that's preventing proper closeure.
Make sense?
Old 04-07-2014, 11:04 AM   #8
2002 25' Safari
Dewey , Arizona
Images: 62
If it isn't leaking, you will know when you take the cap off, I would leave it alone. The handles on mine are adjustable.
Richard
Old 04-07-2014, 11:06 AM   #9
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I had this same problem, and I am sorry to say, I ended up replacing the valve assembly. It is not really a hard job, if the tank is been emptied. Upon inspection of the old valve after it was removed, I found I made the right decision.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 04-07-2014, 11:07 AM   #10
1989 29' Excella
Cumming , Georgia
Thanks Richard, ... Adjustable? How so, ... like turning the T handle clockwise counter clockwise?
Old 04-07-2014, 11:09 AM   #11
blickcd's Avatar
Milford , Ohio
I had the same problem years ago. I took a a piece of garden hose about a foot long and plugged one end. I put several holes in the sides, close to that plugged end, and the opposite end had a female connection. In effect this was a flexible spray wand with jets out the side.
With the valve open, tank empty of course, I weaseled the wand up the sewer outlet and twisted it around while connected to a garden hose. I got a lot of little bits of paper and other stuff out, which improved the situation right away, but didn't completely solve the problem.
After that I tried some of that toilet tissue digester stuff. As I recall I had to do several applications before the valve seal was completely clean. The warmer it is outside, the better that enzyme seems to work.
I wouldn't put any acid down the toilet. You might end up destroying the valve, and maybe even the holding tank.
Christopher
Its a camper, therefore it leaks.
blickcd is offline   Reply With Quote
Old 04-07-2014, 11:39 AM   #12
2002 25' Safari
Dewey , Arizona
Images: 62
My thetford valves have the "T" that screws into the valve shaft. There is a lock nut on the "T" that needs to be loosened to make an adjustment.
Richard
Old 04-07-2014, 12:36 PM   #13
HowieE's Avatar
Images: 12
This is the first time I have ever heard of a reason to backflush. It sounds like a good idea.
I would suggest if you do this that you park the trailer street side High on blocks or other means. This will keep the water from coming back at you when you remove the hose. Just open the valve about a 1/4 in to insure the flow is forced past the area of the valve that most likely has the issue.
2004 Excursion 4x4
Old 04-07-2014, 01:34 PM   #14
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Adjusting Handle
I had the same problem until I discovered I could turn the handle clockwise and screw it in until the clips would fit. I checked my gray water valve handle and it works the same. If, as azflycaster suggests, there is a locknut on the shaft, mine must be loose. Now I have to go check and tighten it up.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Sticky Black Water Valve squeeky Waste Systems, Tanks & Totes 3 04-09-2004 10:47 AM
frozen black water dump valve Rick Alston Waste Systems, Tanks & Totes 6 10-28-2003 01:17 PM
Black Water Valve Opinion Deppdog Waste Systems, Tanks & Totes 4 09-11-2003 04:27 PM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
