Old 04-23-2012, 10:18 AM   #1
Clueless but willing
mamos's Avatar
1969 21' Globetrotter
Falmouth , Cornwall
Send a message via Skype™ to mamos
Black water tank material
Hi All
Things are progressing with the re building of out 1972 Globe Trotter.
We have to do some work to the black water tank.
It is made of plastic and we need a glue that will stick to it.
The plastic is quite soft like Tupperware and is a greeny blue colour.
Any idea what the actual material is so i can find a glue.
The glue need to stick to the plastic and fibreglass
Any help would be really appreciated
mamos
mamos is offline   Reply With Quote
Old 04-24-2012, 03:17 AM   #2
mamos's Avatar
Falmouth , Cornwall
I have constructed a new tank out of fibre glass and I want to bond the tank fittings into the new tank
I have tried sikaflex but even this does not stick to it
Old 04-24-2012, 04:50 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The black water tanks are made of polyethylene. No glue sticks to it. You should use fittings made of the same material and weld them into place.
Old 04-24-2012, 05:34 AM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
West System Epoxy makes an epoxy glue called G Flex. Folks use it to attach hatch covers to kayaks and other plastics. The sheet says it will work on poly. Might be worth a try. I have use it on several plastic items with good success.
http://www.epoxyworks.com/25/pdf/G-flex_Epoxy.pdf
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 04-24-2012, 05:36 AM   #5
1973 25' Tradewind
Augusta , Georgia
Check out West Systems G-Flex epoxy. They have a video where they cut a plastic kayak in half and then "glue" it back together. I've used West 105 epoxy for years building small boats and canoes. The G-flex is new formulated for roto-molded plastics. I've used it for small projects. I picked up a guart last week from West Marine (a different company that sells West Systems), it's expensive. I hope to fix some cracks in shower pan and other ABS parts in the next few weeks.
http://www.westsystem.com/ss/g-flex-epoxy/
DGJackson is offline   Reply With Quote
Old 04-24-2012, 06:14 AM   #6
mamos's Avatar
Falmouth , Cornwall
WOW
That looks like the stuff for the job
Thanks guys
