Old 12-05-2016, 02:47 PM   #1
cbrittan's Avatar
2016 30' International
Woodstock ON , North Fort Myers FL
Black Water Tank Flush Issues
We have been parked for 4 weeks now in SW Florida enjoying pleasant weather. We expect to remain in this location without moving for the next 4+ months.
With 22 years of RV ownership, often in static locations for extended periods of time, and having owned 2 other AS's in more recent years, we have never experienced any issues related to the efficient and trouble free disposal of waste from blackwater tanks. We do not deposit toilet paper into our toilet. We rarely use commercial digesters as the tank contents are dumped (never more than 3 days) before such additives have enough time to work their magic.
This particular AS model (Serenity) also dumps it's bathroom sink grey water into the black water tank, while kitchen and shower waste flow to the gray water tank. The purpose for this is said to be to add further water to the black water tank to enhance it's dumping. The effect of this however might force occupants to use the kitchen sink for personal needs to avoid filling the black water tank with bathroom sink water when capacity of the blackwater tank is needed for human waste.
We always use the factory recommended "freshwater flush" system to further enhance the blackwater dump procedure.
We find the tank flows out quickly when full, slows rapidly giving the impression that the output plumbing line is either small diameter or partially obstructed. Eventually, after extended freshwater flushing, effluent becomes clear and the tank is apparently clean and completely empty. Observing tank condition from above confirms that there is still significant waste materials that failed to exit during the dump.
Comments and suggestions welcomed.....
cbrittan is offline   Reply With Quote
Old 12-05-2016, 03:04 PM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Unclogging RV Holding Tank
Go to TankTechsRX website for some videos that you might find helpful.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 12-05-2016, 03:07 PM   #3
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Try a commercial digester.
Mike
Caffeinated is offline   Reply With Quote
Old 12-05-2016, 03:29 PM   #4
Long Island , New York
Airstreams are not designed to remain stationary, and also have the black water waste dump easily. If your previous models did this without hassle, then you may lucked out IMO.
Are you able to move the trailer forward and backwards about 10' each way, once a week or so (or as often as you want to dump the black water)? If you do so, and hit the brakes firmly a few times, in the middle of each journey to and fro, you will at least have a chance that those solid deposits will break down somewhat. You might luck out with at least keeping them in a semi-suspension long enough to dump the black water ASAP. If you can make a few loops around the campground instead, all the better.
A regular garden hose stuck down the toilet, with someone else controlling the flow at the hose bib, would help. Previous links to videos etc. may show this, but I haven't watched them. There are spray wands which you can add to the hose to facilitate the action I believe.
Good luck!
PS -- If the solid deposits are stuck to the bottom of the holding tank, you did not have enough water/treatment chemical in the tank before the first deposit was made IMO. Solid material dropping into an empty tank should hit an inch or so of liquid IMO. Bigger tanks will require more liquid added after dumping to accomplish this.
Old 12-06-2016, 12:39 PM   #5
"Silver Shrek"
drairstream's Avatar
2000 27' Safari
Crestwood , Kentucky
Three days seems like an inadequate time for adequate fill of waste and fluid unless you've got a washing machine running a bunch or take long showers. I think you need to do a visual via the toilet to check you're getting enough accumulation to need flushing out.
drairstream is offline   Reply With Quote
Old 12-06-2016, 12:49 PM   #6
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
We wrote a humorous blog post on how we dealt with a similar situation. https://livinginbeauty.net/2016/08/2...-and-it-is-us/
2001 Excella 30' (Beauty)
2014 Ram 2500 Diesel 4x4 (The Beast)
http://www.LivingInBeauty.net
JBBeaubeaux is offline   Reply With Quote
Old 12-06-2016, 03:26 PM   #7
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
My 30' FC has the same plumbing as. His; the bathroom sink empties into the black tank.
After three days the black is definately ready for a flush.
Of course, this means very limited boomdocking.
We are two seniors only in it.
Trailer Trash awaiting Spring
MelGoddard is offline   Reply With Quote
Old 12-06-2016, 03:48 PM   #8
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I would use a digester, I would make sure the tank vent is not plugged. I would wait until the tank was full to dump.
larryglarson is offline   Reply With Quote
Old 12-06-2016, 04:29 PM   #9
1975 Argosy 22
Eugene , Oregon
Go get one of those black tank cleaning wands at Camping World or Amazon. Stick it down into the black water tank thru the toilet (with the dump valve open) and BLAST AWAY. You might even be able to stick it up thru the dump valve. If not, stick a hose with a sidewalk cleaning nozzle up thru the dump valve and BLAST AWAY. Anyway, have a blast doing it!
mrdfred is offline   Reply With Quote
Old 12-06-2016, 04:38 PM   #10
1971 31' Sovereign
Temple , Texas
We use septic safe toilet paper and a citrus based digester chemical. After dumping the tank we always add about one gallon of a base solution of water and digester. We dump our tank every 3 days. We have lived in our 1971 Sovereign for 93 consecutive days. No problem whatsoever with emptying the black tank completely. Using adequate water is essential.
TxDave is offline   Reply With Quote
Old 12-06-2016, 04:40 PM   #11
2011 30' Flying Cloud
Greenback , Tennessee
Especially, if he is not putting TP in the black tank, three days is not very long to dump the black water. Maybe they take long sponge baths in the bathroom sink, or they do a lot of tooth brushing with the water running! When boondocking, we catch most of our shower water and put it in the black tank, since gray water seems to be the limiting factor. My guess is that too frequent dumping is the main problem.
Gneiss Guy is offline   Reply With Quote
Old 12-06-2016, 05:04 PM   #12
Journeyman
2016 25' International
Deerfield , Massachusetts
The key word is BLAST.
As an alternative you could just go crazy at Taco Bell and wait for things to run their course!
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 08-14-2017, 01:48 PM   #13
Opinionated newb...
wave man's Avatar
2018 25' Flying Cloud
League City , TX
As a newbie I've been reading a ton lately, what I've read supports what others have said before me. I've seen these points repeatedly stressed:
1. Enough liquid is essential when you set up a "fresh" black water tank
2. A Digester/Deoderizer will work to ahem..soften up any ummm problem deposits that are not cooperating as it were- over time it must help, they seem cheap-ish and a little shopping will surely pay off
3. Enough liquid must continue to be added as you go to ensure a smooth dump process to keep ratios healthy solid to liquid
Good luck improving your situation!
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
wave man is offline   Reply With Quote
Black Water Tank Flush: Park Water Pressure cbrittan Waste Systems, Tanks & Totes 2 08-01-2016 06:32 PM
Fresh Tank to Black Tank Flush (Spray) withidl Waste Systems, Tanks & Totes 19 05-23-2011 06:41 AM
Black Water Tank Flush neil ervin Waste Systems, Tanks & Totes 13 07-26-2010 03:37 PM
Black Water tank flush leaks bfwoz Waste Systems, Tanks & Totes 2 07-06-2004 05:06 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 12:54 PM
