Old 06-12-2015, 07:49 PM   #1
2014 23' Flying Cloud
2015 28' Flying Cloud
Kalamazoo , Michigan
Black water flush question????
What does one do when attempting to use black water flush inlet and the hose has no threads. Just came back from quick trip up north. Went to flush my black tank at dump station. Hose had nothing on hose end. What do you folks do in this situation?
mwilliamsmd is offline   Reply With Quote
Old 06-12-2015, 07:52 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Wait till you get home or where you can use your hose.
MICHAEL
Old 06-12-2015, 08:04 PM   #3
z , North Carolina
Yup
I ran into this situation so many times. I had reached my wits end.
I went & bought the cheapest 20ft hose I could find @ Wallyworld, wrapped both ends with red tape to mark it as non-potable, and I am done fooling with this issue. Just store it seperately from your drinking hose to avoid contamination.
Like the Boy Scout motto: Be prepared!
Gavin
FishinHatteras is offline   Reply With Quote
Old 06-13-2015, 05:32 AM   #4
Appreciate both replies but....
Don't want to wait to get home, would like to dump black tanks at site. Also, I have a "black water hose" I carry but if you are at a State Campground or other campground that does not have water and sewer at the individual sites your are relegated to whatever is available at the dump station.
Old 06-13-2015, 05:40 AM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Is the flush something you do every time? I haven't found that necessary. Someone taught me a great trick in the forums - when you're emptying your black tank (which you've filled with water to 100% full before flushing) you let it drain completely (don't close the drain) then lift the "slinky" above the drain pipe and open the grey tank (also full to 100%) for say 5 seconds and close the grey. That just pushed a few gallons of water back through your blank tank and when you drop the slinky you'll get an extra good flush/rinse. Then complete the grey process as usual.
I also make sure that after draining the tanks, I put some water (couple gallons or so) in the toilet with a Chem pack (some people don't like that) and some water and grey tank sanitizer in each of the kitchen, bath and shower drains. Controls things very well. Has made the backflush far less important.
Good luck!!
SteveSueMac is online now   Reply With Quote
Old 06-13-2015, 05:45 AM   #6
Gainesville , Florida
Flushing the tank should not be necessary if you are using enough water. Pull the valve and then put a gallon or two in the toilet and pull the valve again. When done and valve is closed put some water back into the black tank. Jim
Old 06-13-2015, 07:38 AM   #7
SilverEagle6's Avatar
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up , Traveling the USA
There is a gizmo from Camco called the water thief or hose thief. Cost about $4. It slips over the end of the cut off hose. You may have to hold it on depending on pressure. It works great and we use it quite often.
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
https://instagram.com/silvereagle3100/
SilverEagle6 is offline   Reply With Quote
Old 06-13-2015, 07:49 AM   #8
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Or use a hose clamp so you don't have to hold the water thief on.
Hiho Silver is offline   Reply With Quote
Old 06-13-2015, 09:09 AM   #9
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
I have a little plastic bag of different size male hose ends with with a simple screw clamp and a small screw driver. It only takes a minute to put one on.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 06-13-2015, 09:13 AM   #10
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
I carry a slip joint wrench and just take off the dumpstation hose and put on my own. Of course I replace the original hose when done.
remphoto is offline   Reply With Quote
Old 06-13-2015, 09:53 AM   #11
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We carry a flexi hose in the rear bumper with one section of sewar hose. When I run into this I detach the dump station hose, attach my flex hose and proceed to clear her out. Then reverse. That said I usually try to end any trip at a full service campsite and do all that at the site the last morning. Works well for us, can't use the toilet on our last leg home, but no big deal.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 06-13-2015, 11:32 AM   #12
gecko's Avatar
2009 28' International
Pacific Palisades , California
Not necessary to use the spray after every outing--just good to do so on a regular basis. As suggested, if you are traveling every day for several days, invest in a a full service site so you can hook up that second, sewer use only hose that you always with you!
gecko is offline   Reply With Quote
Old 06-13-2015, 11:54 AM   #13
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We add our dishwater to the black tank through the toilet the last day before we leave a campground (if there's room in the tank...making sure the dish water doesn't have a spoon or fork hiding in it) to add water volume to the black tank. We don't use the rinse system every time either...usually at our last stop of a trip, and if there's no line to dump...and, of course, if there's a threaded hose at the dump station (and many times there is not).
TB & Greg and Abbey Schnauzer
#3954
Old 06-13-2015, 12:33 PM   #14
JimGolden's Avatar
1977 31' Excella 500
Old Trick
Another old trick (my 87 has no hose rinse provision for the black tank) is to put a bag of ice cubes down the toilet after emptying the tank at the campground. The solid cubes will scour the inside of the tank and get the junk that's stuck broken free. Then the cubes melt and it's all liquid happiness that you can dump at the next stop six hours later.
- Jim
JimGolden is offline   Reply With Quote
Black Water tank flush leaks bfwoz Waste Systems, Tanks & Totes 2 07-06-2004 04:06 AM
New Bambi 02--Black Water Flush ? WayWard Wind Our Community 12 02-19-2003 07:29 AM
Black Water Flush--Bambi 2002 WayWard Wind Waste Systems, Tanks & Totes 0 02-18-2003 08:21 PM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
Black water flush davidz71 Waste Systems, Tanks & Totes 14 04-28-2002 04:15 PM
