Old 09-25-2015, 11:15 AM   #1
2012 25' FB Flying Cloud
Grand Rapids , Michigan
Black Tank Valve Help
I'm having a problem with the black tank valve on my 2012 - 25. The valve closes enough to stop any water running but not enough to attach the holding clips to the handle. I've run water through thinking something may be stuck, I've run the valve in and out several times, and run down the road with stuff sloshing to clear any possible block but nothing seems to work.
Any ideas?
Jwestman is offline   Reply With Quote
Old 09-25-2015, 11:40 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Is this a recent development? Can not the length of the value arm be adjust. I think I remember seeing a lock nut behind the valve handle on my AS black valve handle.
Kelvin
Old 09-25-2015, 12:39 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Yes, you can loosen the lock nut and adjust handle length.
CRH is offline   Reply With Quote
Old 09-25-2015, 01:18 PM   #4
Thanks, I'll give that a try
Old 09-26-2015, 10:57 AM   #5
hollycwright's Avatar
2016 25' Flying Cloud
We are having the same problem. Everything was fine until a few days ago and now it won't close enough to reach the pins.
hollycwright is offline   Reply With Quote
Old 09-26-2015, 11:14 AM   #6
2007 27' Classic FB
Ridgefield , Washington
I have this problem periodcally. When I run a blacktank flush it closes fine. Not sure what the issue is.
John & Lisa
Woosch is offline   Reply With Quote
Old 09-26-2015, 11:59 AM   #7
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I recently had the same problem. Rebuilt the both valves, even though the grey water was still OK. Found an amazing amount of dirt and crud buildup in the black water valve seat.
Amazing what a difference that a new set of seals and gaskets did.....
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 09-26-2015, 12:05 PM   #8
1967 26' Overlander
Spartanburg , South Carolina
I am not too sure about you folks with newer rigs but when I had the same prob with our '67 I bought a soft bottle brush with a long handle and with the valve wide open, ran it around the valve seat several times to dislodge the debris that was impacted in it. That was over 20 years ago. Since then I make sure the tank is full before I open the dump valve. Then, leaving the valve open, I fill and flush the toilet, which holds about a gallon of water, three times to wash any residual solids out of the valve seat. You guys with newer rigs can do this with your tank washing systems. Never a prob since (knock on wood). I hope you realize the valve should always be left closed until time to dump, otherwise debris will accumulate in the valve seat.
Jacob D is offline   Reply With Quote
Old 09-26-2015, 06:26 PM   #9
2005 31' Classic
Gretna , Nebraska
That is a problem with the newer trailers - no access to clean the valve seat. There is too much plumbing with the two tanks compared to the earlier units that only had a black tank.
Dwight
16595 is offline   Reply With Quote
Old 09-27-2015, 07:05 AM   #10
Well, with Urban Air coming up this week it's now in the hands of the local repair guys. I tried everything I could think of and nearly all of your suggestions - thanks! - but really didn't want to risk leaving a souvenir for the nice folks of Eaton Rapids. ��
Old 01-16-2016, 08:18 AM   #11
2015 27' Flying Cloud
maple grove , Minnesota
Same problem with 2015 27 flying cloud
thebreezeman is offline   Reply With Quote
Old 01-16-2016, 08:40 AM   #12
Let us know what they find
Old 02-03-2016, 07:34 AM   #13
2011 27' FB Flying Cloud
Box Elder , South Dakota
We just had the same problem. Over time, sludge and debris build up in the tank and around the flush valve. You can use a good cleaner, like Happy Camper Extreme Cleaner, or you can purchase a "Flush King" back flush devise. After filling the tank at least 1/3 full, and letting it soak for 24 hours, we tried the Flush King. After several back flushes, all the loose debris was flushed out of the tank and away from the valve. The valve is, once again operating normally. The Flush King is now part of our "Full Timer" inventory !
joanbob27 is offline   Reply With Quote
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
HELP frozen black water tank, not valve wildwoodmusi Full-Timing, Winter Living & Workamping 21 01-20-2009 03:37 PM
black tank leak above valve gary Waste Systems, Tanks & Totes 2 06-03-2004 08:42 AM
Black Tank Valve Repair 87MH Waste Systems, Tanks & Totes 4 01-27-2004 06:47 PM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 08:21 PM
