Old 05-19-2016, 03:55 PM   #1
2006 19' Safari SE
Hayes , Virginia
Black tank Valterra valve replace
Changing Bambi 2006 black water valve. Have removed old one and cannot figure out how to install new one as gap too narrow. Any suggestions how to pry gap wider to install gaskets, then slide Bladex Valve 3" into position without disassembling entire septic system? I have checked utube for guidance but the trailers they show are different fittings. Thanks for any suggestions.
mocus is offline   Reply With Quote
Old 05-21-2016, 01:00 PM   #2
2006 19' Safari SE
Hayes , Virginia
Got'em put together. Trailer dealer wanted $50 to repair...next time. I was advised I would probably learn a few new words and I did.
Black tank overhaul: Thetford to Valterra tank fitting conversion/ plastic weld rippie Waste Systems, Tanks & Totes 23 02-19-2017 04:19 PM
Replace Thetford with Thetford or Valterra? evansm1974 Waste Systems, Tanks & Totes 1 10-06-2014 09:01 PM
Looking for Valterra dual dump valve Zstream Waste Systems, Tanks & Totes 4 11-16-2009 10:27 PM
Valterra Valve question 65CV Waste Systems, Tanks & Totes 0 07-14-2009 09:14 PM
Replace a Thetford Valve with a Valterra? thunder433 Waste Systems, Tanks & Totes 2 03-03-2008 04:41 PM
