Old 07-16-2019, 11:11 PM   #1
Black Tank Spray Not Working (2002 25ft Classic)
Just purchased the AS and when I dump the black tank and follow up with attempting to spray nothing. It seems like the water just won't make its way thru the system to the spray head. Valve problem? clogged spray problem?
Thanks in advance
umasslax is offline   Reply With Quote
Old 07-18-2019, 09:07 AM   #2
2006 28' International CCD
Houston , Texas
Had the same problem on my 2006 Classic. The problem is the spray nozzle openings are so small (think the size of a #2 pencil lead) that they log up very easily. Jackson Center will tell you to dump your tank and flush with water from toilet then drop several packets of tank cleaner in and fill holding tank with water and let sit for a couple of days. This did not work for me. Ended up taking it to JC and they removed spray head and drilled out holes.
The trick is always clean out tank before leaving campsite or it is subject to clogging.
28totow is offline   Reply With Quote
Old 07-18-2019, 10:11 AM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
You might be able to have some luck unclogging the spray heads by mixing up 4 parts water and 1 part Liquid Calgon And one part dawn detergent and putting it down the spray connection. Use a funnel or recycler any largish plastic bottle with a squeeze head... catsup, shampoo, dish detergent, etc.
Let it sit for a day or two and then try it again.
Old 07-18-2019, 01:31 PM   #4
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Same issue on my 2008 Classic 25fb. I had the nozzle replaced. Make sure you run the water through your hose before connecting to flush out any rust or debris.
Old 07-18-2019, 01:40 PM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I had the misfortune of hooking up with a hose that was dropped in sand and dirty then assumed nozzles got clogged from the debris.
Oh Pooh.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 07-18-2019, 02:27 PM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Mine didn't work. While replacing the dump valves I pulled the nozzle, soaked it in bleach, drilled out the holes put it all back in and it still didn't work. Since cleaning out the holes in the nozzle I now get tank odor in the bathroom when the AC is running. I now suspect the vacuum breaker valve under the sink. I have seen posts where the vacuum breaker was replaced with an elbow and a separate vacuum breaker was installed on the flush line input. That project goes to the bottom of my to do list.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-19-2019, 07:16 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
After sitting, apply steady 35 psi air pressure.
You could MacGyver a similar fitting, I use this to clear the water heater.
ID:	347047   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
black tank spray head/ 2001 '34 Limited truxpin Waste Systems, Tanks & Totes 5 05-05-2015 11:29 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Nice 2007 airstream safari 25ft travel trailer snice 2007 airstream safari 25ft trav eBay Watch Airstreams on eBay 3 12-31-2011 02:09 PM
Fresh Tank to Black Tank Flush (Spray) withidl Waste Systems, Tanks & Totes 19 05-23-2011 05:41 AM
