Old 03-08-2012, 06:21 PM   #1
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
black tank odor filled trailer HELP
While set up full timing it after 3 months of use the wind was blowing from the rear 25 to 35 mph and when I opened the door it was like I stepped into the black tank . Apparently the wind was syphoning the methane up the tube and it was sucked in by the a/c. Even when I walked around the rig I could smell the odor sweeping across the roof . Since this is a new to me trailer (93 Excella 30)and everything worked fine for 3 months I checked the roof vent and I found the black PVC pipe is near the top of the aluminum rectangle? Is this correct or should it be flush with the roof rather than almost flush with the top of the square vent?
(I added a 2 foot extension as a patch , duct taped it to the vent, and the odor is gone)
arcamedies is offline   Reply With Quote
Old 03-13-2012, 04:23 PM   #2
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
wow over 100 views and no one has an idea, I figured somebody would take a mirror and ladder and look to see on theirs. bummer
Old 03-13-2012, 04:35 PM   #3
2005 19' Safari
GLENDALE , AZ
Perhaps, this problem is uncommon. Our 2005 model does not have a vent like you describe. Also, I don't think our air conditioner pulls in air from outside the trailer; it only recirculates the inside air. (We have the a/c with heater element, not the heat pump.)
Do you use deodorant in the black tank?
Old 03-13-2012, 04:59 PM   #4
1999 25' Safari
Fairburn , Georgia
That is the correct vent for your trailer.
If the trailer is hooked up to a sewer connection and either drain valve is open, it is venting the entire septic tank system from the park into the air. The dump hose should have a "u" in it, like a trap under a household sink, to prevent vapors from coming into your trailer vent system. That "u" retains water just as a trap will.
JackMac is offline   Reply With Quote
Old 03-13-2012, 05:07 PM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Keep your drain valves closed unless you need to dump the tank. Guaranteed no back up odors from the sewer system. Otherwise the vent configuration sounds correct.
Kay
Old 03-13-2012, 05:21 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The vent pipe should not be level with the roof, 4-6" would be normal.
On our's it's about six high and two inches from the top of the vent cover.
It may have been the wind causing pressure in the tank and a bad seal in the toilet valve letting the bad stuff in. I also don't think the AC draws from outside the trailer.
The toilet valve got stuck once on our 63 Safari, had to be manually closed.
Let it sit over night closed with 1/2 cup olive oil, never stuck again.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-13-2012, 05:34 PM   #7
Your AC recycles the interior air, only.
There is no way that the AC can pump outside air into the interior.
Old 03-13-2012, 05:36 PM   #8
I should have added that if the sewer vent pipe cover gasket is bad, it could possibly have contributed to the issue.
That gasket is only good for 2 to 3 years.
Old 03-14-2012, 02:19 PM   #9
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
odor backup
That's a thought, the wind was cranking 20+ and could have pressurized the black tank, just wondered how far below the lip of the aluminum stack on the roof the black plastic pipe is from the top, mine is almost even. Never had this problem with my Argosy or my motorhomes (4 in the last 40 years) before. Adding the 2 foot extension which looks like a periscope stopped it but can't drive down the road like that duct tapped to the aluminum cover.
Old 03-14-2012, 02:23 PM   #10
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
vent gasket be old
I was going to replace it but still wanted to confirm whether the black pipe is even with the top of the aluminum stack or should it be below it an inch or two?
Old 03-14-2012, 02:38 PM   #11
[QUOTE=arcamedies;1120017]That's a thought, the wind was cranking 20+ and could have pressurized the black tank, just wondered how far below the lip of the aluminum stack on the roof the black plastic pipe is from the top, mine is almost even. Never had this problem with my Argosy or my motorhomes (4 in the last 40 years) before. Adding the 2 foot extension which looks like a periscope stopped it but can't drive down the road like that duct tapped to the aluminum cover.[/QUOTE
arcamedies,
I would think you would want at least 2" between the top of the tube and bottom of the vent cover...maybe Andy could chime back.
PFC
"Tahawus"
RLC
John Prine
Old 03-14-2012, 03:41 PM   #12
CallDon's Avatar
1986 Argosy
Dallas , Tech-Sus
I have a suggestion that some folks may not like. About a year ago on this forum or another RV forum, some were discussing a different way to treat holding tanks, since they are "holding" tanks and not sewage treatment plants. Instead of harsh chemicals, you put in water softener (not fabric) for two or three tank cycles. The water softener helps keep "solids" in suspension and not on the walls of the tank.
Then you use laundry detergent and bleach instead of the expensive chemicals most people use. The bleach helps with the odor. The laundry detergent helps clean the tank.
This cuts down on the odors that the usual RV chemicals never seem to be able to take care of.
EDIT: I found it. It is called the GEO method. Here is the link to a longer description of the GEO method for treating your tanks.
Don
Life is too short. Do it NOW!!!
The Don Pod
Airstream FM
Easy Listening For the Internet Generation
CallDon is offline   Reply With Quote
Old 03-14-2012, 03:53 PM   #13
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
EDIT: I found it. It is called the GEO method. Here is the link to a longer description.
Don
We have been using the GEO method for several years and have been very happy with it. We do not full time. Our longest trips are usually three weeks. We do not have any black tank odor. We do not use bleach, just liquid Tide and Calgon liquid water softener.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 03-14-2012, 04:12 PM   #14
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Our airstream suddenly had a horrible horrible black tank odor once. It filled the trailer and was nauseating. I read on the forum that using a metal bent coat hanger I could swipe e seal of the toilet and see if a tiny tiny bit of debris was not letting it seal completely. Sure enough, all the water was draining out of the bowl very slowly, and once it was gone the odor would come. I did the coat hanger trick and the seal worked perfectly again and we have never had the odor again.
Skatiero is offline   Reply With Quote
Need help with Interior End Caps Davis Upholstery, Blinds, Walls & Interior Finishes 11 04-06-2012 06:25 PM
Gas tank 1/4 full on bifuel generators?! Toller Generators & Solar Power 4 03-11-2012 08:05 PM
Need Help Deciding on Airstream Smith77494 Dollars & Cents 18 03-09-2012 06:10 AM
Help towing an Airstream Safari from AZ to CA drmittens On The Road... 4 03-08-2012 11:45 PM
1982 silver streak continental supreme 35 foot travel trailer vintage airstream eBay Watch Airstreams on eBay 0 03-08-2012 06:00 PM
